![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
944GTTE Project
Pardon the quality of the images but the majority were taken on from my cellphone as i went.
I might have posted this log before the jack. This has been my ongoing project since the summer of 07 and is nearing completion. The car is a 1986 Porsche 944 The engine Toyota 1JZGTE I will add descriptions to the picture over the next few days as this is a lot to post all at once. ![]() ![]() ![]() ![]() ![]() ![]() ![]()
![]() 12.5 lbs lightweight 1jzgte Flywheel Direct from Japan, $230 ![]() Stage II pressure plate came with 7mgte disk (if you need the 7mgte clutch disk I still have it) ![]() Machined the center clutchhub and spliced it with the 944 bearing. ![]() I had to pull the manifold off to put the new wiring harness on decided to clean it up and paint it with caliper paint while i had it off. Just some color for now. ![]() ![]() ![]()
![]() layout for the adapter plate, matching the stock automatic bellhousing to the torque tube. ![]() cut out and drilled. ![]() Finished plate with the alignment bolts for the torque tube. ![]() machined out the bellhousing for the clutch fork and slave cylinder ![]() Test fit of the engine in the engine bay. ![]() The engine In the engine bay and mounted to the torque tube. ![]() ![]() ![]() The motor mounts fabricated on spot with the engine in the car. ![]() ![]() Engine sitting in the engine bay on the new motor-mounts. The rubber 944 bottom bushings will soon be replaced to change it to be a solid mount. Last edited by ka0sx; 02-10-2009 at 01:41 PM. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() missing map sensor..... ![]() ![]() ![]()
that is going to be fun when you're finished! Good luck!
excellent powerplant choice!
Beast
hah wow... what a coincidence.... why not an LS1?
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! |
Bacon!
Drives: 2008 Red Yaris LB Join Date: Oct 2008
I had to laugh at the picture of you upside down in the drivers seat. I can't count the number of times I've been in the same position.
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Holy shit ! Thats the first time I've ever seen a 944/1jz swap very nice work man , the install looks super clean .
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Yaris Join Date: Oct 2008
Freaking awesome..
yum... one of my favorite Porsches with a more modern, badass engine...
#14 |
H8R
Props for the work. I'm sure you must be excited to take it out for a rip.
I personally wouldn't have painted the piping blue, but if it floats your boat then good on ya.
#15 | |||
LS1 = aprx $2500 + shipping 1JZ only cost me $1000 shipped. LS1 and LT1s already have kits for them. After every thing is tested I plan to have the parts machined, documented, patented and maybe even sell kits. who knows. I also love the Toyota engines. Quote:
So that is my biggest issue right now. |
#16 |
Weather sucks
Cali Weather has sucked ass lately, I have had enough clear time in between all the rain to install the "heater" radiator with a higher water reserve point. Will have pic up soon, have also removed some more carpeting and dead weight.
Now that the plumbing is done for the extra radiator I have two more things to do before I test drive it. *brake booster wiring (from scratch now...) *solid motor mounts (no room for engine flex/wobble) |
#17 |
§†ęĄ¶‡Ћ-NCP96
badass
#18 |
This is an amazing project... Great work mate
| New Project AE86...! | CASTREX | Photo-Video-Media Gallery | 29 | 02-01-2009 03:09 AM |
| Project for a friend | wsladaritz | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 01-07-2009 09:38 AM |
| delayed turbo project... | joey1320 | Forced Induction Forum | 8 | 09-26-2007 11:18 PM |
| Re-Wiring Project - Any advise before I begin? | vodkalush | DIY / Maintenance / Service | 12 | 05-13-2007 06:22 AM |
