Old 02-23-2009, 11:36 AM   #1
1stToyota
1stToyota's Avatar
Originally Posted by mikenacarato View Post
hey 1sttoyota...let him blow his engine up...its ok :)
But the next thing you'll know is that he'll pretend that he hasn't been going around for months telling others to use 0W-20 because he's **used it for 50+K miles with no problems**, but I guess he's got the UOA's to prove it, but I've never seen him post those UOA results yet.
I doubt that he's put that many miles on his Yaris since the TSB was issued. The 50+K miles is probably the actual miles on the car, not how many miles 0W-20 has worked for him.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 02-23-2009, 11:23 AM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
Old 02-25-2009, 06:34 PM   #3
ChinoCharles
Drives: LB
ROFL
Old 02-23-2009, 12:06 PM   #4
jkuchta
Drives: 2007 Yaris hatch (red)
What Silverglow doesn't know (because he dosen't have an oil temp gauge), is that under normal driving (city, and 75mph highway cruise), the oil temp does not go above 85 degrees C.
At the track, I've seen 109 degrees C at the end of a 25 min. session, but that was 25 min. playing above 5000 rpm.
I don't know what the curve looks like as far as temp. vs. viscosity, but I'd be willing to guess that he's not seeing the full 20w most, if not all, of the time.
That would be my guess as to why the TSB specifically does not list 0W-20 as a sub for the 1NZ.
jkuchta is offline   Reply With Quote
Old 02-25-2009, 12:57 AM   #5
spookz
JDM yO!
Drives: '09 3dr. 5-spd
So.. I'm getting quite lost in this thread..
Which is a thinner oil? 5w20 or 5w30?
and also is thinner better?
What do you guys think about the Motul 300V line of oils.. =P compared with the RP motor oils? (mainly the 300V Power Racing)
Last thing.. are some of you saying the RP motor oils are semi synthetic?
Thanks in advance =)
Old 02-25-2009, 08:46 AM   #6
TheSilkySmooth
TheSilkySmooth's Avatar
You may want to try the Motul BMW LL01, prob the best all round oil around. I'll attach the spec sheet. The 300 v while it may work on the street for a bit is a racing oil. Sometimes they lower the detergency to reduce preignition, you need that detergency on a street motor. Cheers!
Old 02-25-2009, 10:10 AM   #7
elmo
WFO
elmo's Avatar
Drives: 2008 hb
Jesus Christ folks the world ain't goin end because you guys have different opinions on oil.
i use pennzoil platinum 05/30 but frankly i think our cars engine would run just fine on ANY 5/30 syn or dino
hell if you want to run something other that what Toyota says go for it just don't cry when you break it !
elmo is offline   Reply With Quote
Old 02-25-2009, 06:24 PM   #8
spookz
JDM yO!
In Australia, it doesn't seem like we have a particular oil by Motul listed as BMW LL01.. But I've come across this one which does have the BMW LL-01 approval, is this the Australian Market equivalent?
Motul 8100 X-Max
The specifications seem similar - 100% synthetic, ester based, 5w30..
Old 02-25-2009, 11:27 AM   #9
TheSilkySmooth
If I was lucky enough to live in FLA, SoCAL or DownUnder, I'd be running Straight HD 30, absolutely NOT a winter oil. VI improvers are not lubricants and are the leading cause of varnish and sludge and shearing out of grade. Our engines do not take kindly to varnish and are not THAT easy on oil given they have: the dreaded flat tappet cam, hydraulic cam phasing, timing chain and guide and a hydraulic chain tensioner.
Old 02-25-2009, 11:32 AM   #10
TheSilkySmooth
My 145 dollar 3.5HP briggs lawn mover is still alive after 19 years having only summer use, 30wt hdeo oil fill with OC every OTHER year. Burns no oil, doesnt knock. It has NO oil pump, just splash lube. OK thats my 300th post. WEEEeeee!
Old 02-25-2009, 12:00 PM   #11
jkuchta
I run the Motul 300V 5W-30, and love it. This oil is designed for Le Mans....3-4K miles at full speed with no oil changes...I think it's more than enough for the street, and great for track days.
Old 02-25-2009, 07:22 PM   #12
spookz
JDM yO!
Anyone know how the 1NZ-FE would run with 5w40?
Would it be too thick for the little engine?
Old 02-26-2009, 01:42 AM   #13
phenoyz
phenoyz's Avatar
Drives: yaris
after u change oil, is there something you need to "reset"?
like a honda or bmw you need to reset something.
phenoyz is offline   Reply With Quote
Old 02-26-2009, 01:59 AM   #14
If the maintenance light turns on before you change your oil, then yeah, you can reset that light.
Old 02-27-2009, 10:30 PM   #15
spookz
JDM yO!
Does anyone run 5w40 oils in their 1.5L Yaris?
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Aside the name,y is Royal Purple purple? Yawesh General Yaris / Vitz Discussion 6 01-10-2009 06:50 AM
AMSOIL vs Royal Purple IllusionX DIY / Maintenance / Service 44 12-02-2008 12:35 PM
Royal Purple FTW Nibs DIY / Maintenance / Service 11 09-28-2007 01:06 PM
Anyone familar with Royal Purple synthetic oil? Yaris_Fan DIY / Maintenance / Service 34 06-23-2007 12:29 AM
