Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Here ya go bro
http://www.yarisworld.com/forums/sho...t=engine+cover |
#2 | |
§†ęĄ¶‡Ћ-NCP96
*EDIT: sorry, read your other post and saw you got it from garm |
![]() ![]() Drives: '07 blazing blue hatch Join Date: Oct 2008
I have a hi flow filter with a cut airbox and have noticed better MPG and higher RPM performance
2007 HB Blazing Blue |
Dogging on K&N is a popular thing to do because they're so big, but here in Ohio we have these things called race tracks and guess what filters they use on the cars?
K&N's are tried and tested. I don't run one, but I wouldn't hesitate to.Oh, and they stand up extremely well to wear and tear. My friend has one that he has been running for 150,000 miles and it looks to be in better shape than my generic, which I've had about 25% as long. |
MetalShark
Drives: 2008 Yaris LB Join Date: Oct 2008
I've been running K&Ns on the big V-8s for years. I clean them once a year and re-oil. On my truck its a whopping 14" diameter by 6" tall so I never have a measurable restriction even when its caked on. Typically these types of filters do a better job of cleaning the air after they are dirty up to a point. I've had the big trunicated cone type on a CAI inside the left front filter for one year now. Its been in there for 20,000 miles so its time.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header. |
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
yeah and I like my TRD one witch I think is the same thing as a K&N right? Ever since I put it in I noticed a tad more umph! not much though
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
#7 | |
here's the umph curve miniscule------------------------tad----------------------VTEC!! MMMMMMMMMBAAAAAAAAAAAHHHHH!!!!!
![]() ![]() ![]() ![]() Drives: 2008 Yaris HB Join Date: Oct 2008
be careful with the oil,it can gunk up the MAF really quick and give you a CEL.
And that intial 1hp at the wheels (until the PCM adjusts for the extra airflow that it now sees) that you think you're feeling because you're driving more aggressive to hear the extra noise being made under the hood can quickly turn into about a 20hp loss at the wheels when the MAF gets gunked enough to set a code.
#10 | |
its a common misconception that an oiled filter with screw up your maf....its gross user error to have that happen... as for the hp increase...im sure its almost negligible in the yaris....but the ecu doesnt compensate in the way youre describing, otherwise you would never feel any power increase for any mods done on a stock ecu...and thats just not the case. how much are those stock paper filters? for me, id rather spend the $50 on 1 k&n and never have to spend money on cruddy, restrictive paper filters
#11 | |
And it kinda depends on the location of the MAF, if it's real close to the airbox better chance of catching non-100% air across its heated wires. I'd say it's not a misconception when TSBs are issued on oiled filters. K&N (drop-ins) is great for saving money but not for HP gains, maybe 1 or 2 hp at the wheels of most applications, at best. Probably saw better gains back when they first came out and was installed in bigblocks with hi-rise manifolds and dbl-pumpers, but now cars are getting too smart for minor mods w/o reflashes. |
The bottom line is simple to understand. As "thebarber" said, it doesn't take much to figure this out. WHY spend $ on cheap quality paper filters every couple months, if you can just get something that will less you a eternity for less then $50.00 bucks? Even IF you don't see any significant changes as some of you described previously, just the fact the you don't have to keep buying these filters over and over again, pays for itself.
Now, use your best judgement!
GioBatera
It's no big deal
In a perfect world no one will ever over-oil their filter, and if they do they'll always be smart enough to clean the MAF and have a code reader to see the MAF code and not have to pay a mechanic to read the code and clean the meter at a pricely sum, if the mechanic doesn't decide to make a MAF sale instead of just cleaning it. 50$ investments can get quite expensive.
had to be a need ...and paper filters are good for 15k miles, a year or more for most, not every 2 months |
ya, i agree....no gains even on the butt-dyno...i have one in the yaris and it still chokes past 5500 or 6000rpm - - i just bought it because i hate paying a toyota tech to install new paper filters when i can run w/ a k&n and clean it myself...
gains would be easier to get on larger displacement engines too....though i talked my dad into a k&n filter on his 3.8L (or is it 3.9?) v6 gmc sierra (2006, iirc) and i couldnt really feel a difference...but he says he gets a couple more mpg now...
#15 | |
At the risk of looking like a jerk it might be worth about 10 minutes of your time, a q-tip and some rubbing alcohol (or the CRC cleaner), because loss of top-end power sometime means dirty MAF. All you need is a small phillips screwdriver to remove the 2 screws. No harder to do then replacing the air filter. Might be worth giving it a try to see if that improves the top-end acceleration.
rarer than JDM -1 of 1!
I have a K&N airhog on my wrx for the past 5 years with no ill-effects. Like ChinoCharles stated, it's a race car, so whatever.
I got a Blitz LM intake on my yaris, and it seems to do the trick just fine. If I had'nt got it, I'd be rocking a K&N filter. You haters are overanalyzing the situation. It's not like were talking about crank pulleys that throw off your harmonic balancer. They make balanced ones for race cars, but they cost 4x as much. IT is safer, as you have much more invested in the motor should it crap on you. |
#17 | |
#18 | |
![]() I've never had a problem with the maf getting clogged up with oil, but have had carbon buildup problems with the IAT sensor on my wrx, and also water coming in the fenderwell clogging my filter after like 90 straight days of rediculous rainstorms. |
| DIY Cabin Air Filter | BailOut | DIY / Maintenance / Service | 100 | 06-20-2019 12:59 PM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| Cold Air intake with k&n filter | _S7V7N_ | Performance Modifications | 23 | 12-19-2008 02:36 PM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 02:00 AM |
| K&N 57i filter for TS 1.8 | jim TS | Performance Modifications | 5 | 06-24-2007 05:00 PM |
