Old 03-02-2009, 11:09 AM   #19
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Yeah it's like they said, If you shift to R while moving forward, you will hear a loud crank noise, at this point you should freak out and let go of the shift knob, the box should spit the gear the neutral, then place it in the correct gear. The shift box is designed to spit you to neutral when a gear isn't properly engaged. It has happened to me when I don't pull the stick all the way then I rev and go no where. Re-clutch and engage the correct gear and you're off!
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 03-02-2009, 11:14 AM   #20
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
lol, automatically eh?
that's some priceless misinformation right there
Originally Posted by xnamerxx
you nailed it sir.
Old 03-02-2009, 01:03 PM   #21
IllusionX
Drives: 07 Yaris Sedan Aero
hmmm I guess most of us never dared to try so cannot speak from experience
let my mini cooper S (6 speed MT) friend drive my car once. Did, tried, done. It won't go in "6th" lol
Originally Posted by Ryu View Post
What if you have a automatic, will you be able to shift back to reverse while driving?
I know that would be totally stupid to do so and no one should attempt, but just thought to ask.
tried that in a chevy uplander. It felt like the transmission was about to fall off.. tires would squeak like if you brake enough to lock the wheels (no abs). Tried it once... will never do it again, now i know what it is. please, don't do it on your automatic yaris. Wait untill the car is still before you put it in reverse.
there is really no excuse to mistakenly shift into reverse on any automatic cars.
Old 03-02-2009, 03:04 PM   #22
supmet
Drives: 2007 4 Door Yaris
LOL.. good ole chevy. The Yaris will stay in neutral if you shift into reverse on the freeway in an automatic.
Old 03-02-2009, 03:17 PM   #23
tomato
tomato's Avatar
you've never sat with the engine off and shifted through the gears?
I used to do that every time I had to drive someone else's cars. Clutch always feels a little different from one car to the next.
Speaking of which, I think I'm starting to get used to the clutch on my Yaris, finally. Pfewww, about time, too! It looks like the key to shifting smoothly in low gears with that car is to give it a little more gas, otherwise it chokes.
Old 03-02-2009, 10:55 PM   #24
Ramblin yari
Drives: 08 Flint Mica Sedan
Well, my brother did this to my dads car when he was young and stupid. 55 mph, slammed into reverse.
My dad was furious but never found out why the reverse gear didn't didn't work anymore.
Ramblin yari is offline   Reply With Quote
Old 03-03-2009, 11:57 PM   #25
andru47
andru47's Avatar
Well mine does it, if the shifter doesn't fall into gear right, the spring puts it back to neutral. Of course not unless you keep pushing it into gear, hence I said let go.
My Yaris: The Azure
Old 03-04-2009, 07:54 AM   #26
Tamago
Tamago's Avatar
Drives: ZZW30
you said the box spits the car to neutral then puts itself into gear..
probably just poor wording on your part but it made it sound like the gearbox automatically put itself back into gear
you nailed it sir.
Old 03-05-2009, 11:39 AM   #27
andru47
andru47's Avatar
Ah I see should have put a period there! Yeah it was more like the next step. After that happens re-clutch and (YOU) place it in the correct gear.
My Yaris: The Azure
Werid Noise When I throw it into Reverse LoudYar General Yaris / Vitz Discussion 12 10-26-2020 05:57 AM
reverse gear whine jonismyname DIY / Maintenance / Service 7 03-12-2009 02:17 PM
Yaris 2007- How to Restart Multimode gear? ronen DIY / Maintenance / Service 1 02-21-2009 06:09 PM
Decided on synthetic gear oil caveatipse Performance Modifications 4 10-01-2007 05:57 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 03:44 AM
