![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
ahhh thank you for the insight. how does the tire place know what alignment to give it to make it right? I really don't know so i'm trying to learn
they hang reflectors on your tires and shoot lasers at them. then a computer tells them which bolt to tighten and how much.
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
I have not done this on a newer car but…
I have used a ratchet strap to hold the coils of the spring where they were at. This will let you get them out since there compressed. Once out stick them under a different car and use it’s weight to let them back out. If you try this use your brain. Use a few wraps on the springs. You just need the flat rope (webbing) not any of the metal stuff of the straps; to get the needed friction a clove hitch or two will hold it. I did this with the springs off a 1 ton truck a few times.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
Does installing the springs void the 60k factory warranty?
And one last question is can you take the TRD lowering springs, install them then get an alignment and your done? Or do you need one of the lowering camber kits or something like that. I was reading a story about someone who installed some eibachs I think it was and they had to order a specific camber kit or something so the shop could do a proper alignment because they could not do it without it. I'm kind of confused by that story of the person and then about how it says the TRD lowering springs does not change the vehicles suspension and handling geometry. Last edited by detroiter; 03-21-2009 at 11:43 AM. |
#5 | |
#6 | |
This is exactly what I did. Put the TRDs on and got an alignment. Simple. BTW. I just today installed Cusco GT-Zero Coilovers and did it the way the DIY here states by removing the wiper motor, etc.. IT WAS WAY EASIER THAN NOT REMOVING WHEN I PUT ON THE TRD LOWERING SPRINGS. TRDs are now gonna be for sale. PM with bids if interested.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
so if i'm installing new shocks and springs then do i just basically ignore the spring compressor part by setting that whole stock assembly aside and just add the new spring to the new shock and then bolt it all back in like the stock strut?
and what do i do with the back ones? i did a quick search and didn't find any DIY specifically on shocks so i thought i'd ask before i just try and wing it. |
aw man! that was a neat PDF. Today, I just lowered my friend's 91 Accord, and now I'm itching more than before to do mine. Cool deal on seeing this thread today -thanks guys
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
What about cutting the bump stops... is that necessary for all springs and shocks? OR are TRD's struts shocks, and springs manufactured so to not need to cut the bump stops? Like the guy did on the Tanabe install?
#10 | |
always toyin'
I'll either DIY mine or get someone else to do it but I'm looking to find out what the concensus is in terms of cutting (or not cutting) the bump stop -- is it necessary or only to be done with certain springs? Which is the RIGHT thing to do? ![]() .
- Procrastinators of the world unite! ...tomorrow. ![]() My Garage.. 'Mild' Drop & Misc..2-DIN GPS/Navi..DIY:Rear Wiper Delay..Ramps/Roll-Ups..Rain Sensing Wipers / Auto-Headlamps |
Cutting the Bump stops depends on the install
always toyin'
Thanks for the reply. So for MY install, most likely I'll be using a set of Eibach ProKit (1" all around) and reusing the stock struts/bump stops... Is the recommendation to cut, or to leave the bump stops as is for my particular install?
For a mild 1" drop leave the bump stops uncut. I'm down 1.5" and didn't bother cutting them.
always toyin'
Thanks WeeYari..
I'm just hoping I won't have to drive all the way to Kitchener to see thebarber to get my springs done
![]() ![]() Drives: toyota Join Date: Feb 2011
can someone explain to me how to do the front suspensions without removing the windshield cowl?
ヤリスワールド
Drives: 2008 HB Join Date: May 2010
I agree with Annn. Removing also allows you to clean up the cowl real well. You would be surprised at what you can find in there, particularly if the vehicle is kept outside.
always toyin'
I spent the extra 10 minutes to remove the cowl, it made the job alot easier wit it out of the way.
| DIY needed for amplifier for sedan install | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 02-27-2009 10:07 PM |
| TRD spring install pics | tristan | Photo-Video-Media Gallery | 10 | 02-20-2009 10:33 PM |
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 09:26 PM |
