DIY : Spring install
This is to help those that would like to try it themselves
enjoy and be careful. |
![]() ![]() ![]() Drives: 08 sedan at Join Date: Dec 2008
they make it look so simple!
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
Good link, but removing wipers and associated cowl covers is not necessary.
____________ Old School Cobble Jockey
I did mine without removing the cowl or wiper blades
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Is it possible to do this without the spring compressor? and i'm curious as well, any negative effects to going with the lowering springs? Also, why would lowering springs cause you to need an alignment done since when the car comes stock from the factory without being driven much it doesn't need one?
Mr. Clean
You need the spring compressor to remove the stock front springs safely. If you are installing shorter aftermarket springs you should be able to install the new springs without using the compressor. No compressor is needed for the rear springs.
![]() ![]() Drives: 2012 Nissan Leaf SL Join Date: Jul 2007
Does anyone know how much I could expect to pay to rent a spring compressor?
I have been toying with the idea of lowering my Yaris, but the cost of install that I was quoted is more than I would want to spend. If I could do it myself lowering will be a much more feasible option, even if it took me all day to complete the job.
Cheers, Ryan |
I'd still like to know what the cons of using lowering springs are and also the reason for why one would need an alignment after installing them?
![]() ![]() ![]() Drives: 2004 Echo HB Join Date: Oct 2008
Your car could bottom out over speed bumps that you could clear before. Stiffer ride the BOSS may not like. Front lip may become intimate with the odd parking curb. Toe in will be effected by the lower ride height.
The toe will be affected by the lower ride height which is the reason for the alignment or it will always affect it?
The one with cheese on it
Drives: '10 Corolla S Join Date: Oct 2008
Look at it this way, as you stand your feet are closer together. Now as you crotch down, you spread your legs apart (changing the position of feet) to accommodate the change in stance. Well, when you lower/raise your car, the "stance" is different. Now the tires are sitting at a different angle to accommodate the new position. So you will need an alignment so that the tires will not wear out prematurely. It is only done at the time you change the springs.
ahhh thank you for the insight. how does the tire place know what alignment to give it to make it right? I really don't know so i'm trying to learn
they hang reflectors on your tires and shoot lasers at them. then a computer tells them which bolt to tighten and how much.
#14 | |
![]() ![]() ![]() ![]() Drives: 07 Blazing Blue LB Join Date: Jun 2007
and I think stock alignment on our car is 0 toe and 0 camber but don't quote me on that... |
![]() ![]() ![]() Drives: 09 yaris Join Date: Mar 2009
I have not done this on a newer car but…
I have used a ratchet strap to hold the coils of the spring where they were at. This will let you get them out since there compressed. Once out stick them under a different car and use it’s weight to let them back out. If you try this use your brain. Use a few wraps on the springs. You just need the flat rope (webbing) not any of the metal stuff of the straps; to get the needed friction a clove hitch or two will hold it. I did this with the springs off a 1 ton truck a few times.
09, 3 door lift back, auto. I live on the road with my wife. We travel as needed for our work and drive up to 4,500 miles in a bad week. |
Does installing the springs void the 60k factory warranty?
And one last question is can you take the TRD lowering springs, install them then get an alignment and your done? Or do you need one of the lowering camber kits or something like that. I was reading a story about someone who installed some eibachs I think it was and they had to order a specific camber kit or something so the shop could do a proper alignment because they could not do it without it. I'm kind of confused by that story of the person and then about how it says the TRD lowering springs does not change the vehicles suspension and handling geometry. Last edited by detroiter; 03-21-2009 at 11:43 AM. |
#17 | |
Autozone will lend you the tool for NOTHING. All you have to do is leave a deposit for them.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
| DIY needed for amplifier for sedan install | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 02-27-2009 10:07 PM |
| TRD spring install pics | tristan | Photo-Video-Media Gallery | 10 | 02-20-2009 10:33 PM |
| Suspension install: Spring Compressors? | Thirty-Nine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 09-18-2007 10:59 PM |
| TANABE DF210 Spring Install [pics] | Chris07LB | DIY / Maintenance / Service | 148 | 07-16-2007 09:26 PM |
