Nothing beats a Toyota!
Drives: 2013 Yaris 5 dr liftback Join Date: Jan 2009
0W20
I know this issue has been talked about extensively, but I am wondering if anyone has used 0w20 for a while and what has been there experience with it? I see contradicting info on using 0w20 and I am curious if someone has actually been using it, what is their experience with it, and have they experienced any engine damage as a result.
Big Dave Indianapolis, IN Synthetic Oil....its in my car.....for at least 10,000 miles! ![]()
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
I know that too thick of a viscosity can have a detrimental effect on cars with VVT, don't know if the same holds true with an oil that's too thin. |
#3 | |
Drives: 2007 4 Door Yaris Join Date: Jan 2009
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Oct 2008
AMSoil SAE 0W-20 100% Synthetic Motor Oil all year round here!
0W20 or even 0W30 won't cause engine damage. The only engines that don't like different viscosity are the HEMI MDS and GM's DOD engines. They're particular about running nothing but 5W20. You could run 15W40 even in a VVT-i engine for all the dealer knows. They won't spend the money to test oil viscosity if a warranty repair comes up. 0W20 will allow for smoother starting in cold climates as the oil will move faster to all vital components. As long as the oil you want to use is labeled on the bottle that it is compatible with a particular manufacturer then there's nothing to worry about. I run Amsoil in all my vehicles with different viscosity. Amsoil even backs up their product with their own warranty should anything happen to the engine and it was proven that the oil was at fault - Amsoil will cover the expense. I've been an Amsoil dealer for four years and have sold thousands of quarts to people with everything from a '08 Audi A8 to a '89 VW Rabbit diesel.
I see all you Canuks use the 0w20, but here in mid America, is it OK?
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
Yes it's ok. Until 0w20 reaches operating temperatures it's lighter and it may free up a microscopic amount more miles per gallon, but if ultimate engine life is your key, or if you drive agressive, stick with the 5w30, or 0w30. In European HTHS ( high temperature high shear)testing 2O weight oils don't meet the standard. The test is run at 150C which simulates the temerature in the main bearings of most engines.
I'm using Amsoil 0W-20. I love this stuff, along with their EA filter.
I don't know if the price difference between Amsoil and Mobile 1 is worth the difference. Can anyone explain why the Amsoil is worth so much more?
#11 | |
0W20 not approved in Toyota TSB
I wouldn't pay any extra for Amsoil's XL series. It's the only one with the API approval stamp, and it's also only A1/B1 ACEA rated, with base stock of 3. You can find equal or better rated oils at discounted prices. That was for Amsoil's XL series...their better oils are higher rated, better additives and higher base, but not API approved; worth the extra money if you don't mind the catch 22.
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
I've used the 0w-20 from amsoil and it worked great. The only reason I'm using 5w-30 amsoil right now is the last time I bought amsoil, I got the 5w stuff for my girlfriends old car and we got rid of it before I changed the oil. Figured it shouldn't go to waste.
#14 |
School'er of hard knocks
Drives: Silver Yaris 4dr. HB Join Date: Oct 2008
Almost all of the AMSoil line-up is "true" synthetic (commonly referred to as 'group 4'), Mobil 1 is an extremely hydrocracked dyno oil (referred to as group 3 or 3), meaning not "truly" synthetic in that sense, but acceptable by the governments definitions.
#15 |
toyota
toyota canada does not recognize 5w-20...i think this is only usa.
#16 | |
Amsoil considers Group III synthetic
edit: http://www.amsoil.com/articlespr/article_xl7500.aspx All Amsoil XL series is group III to get API approval: "AMSOIL Changes XL-7500 Formula To Enhance Oils, Stay Competitive Q: AMSOIL will be using a different formula for its XL-7500 Motor Oils. Why did AMSOIL change the formula? A: Our XL-7500 oils are the oils of choice in the retail oil change market, and primarily because of warranty concerns the customers in this market require API-certified oils. In order to obtain API SL/ILSAC GF-3 certification and still remain cost-competitive with the other oils sold at retail oil change outlets, we had to change to Group III basestocks. To obtain API certification with our top tier basestocks would have priced our Dealers out of the market. Q: Are Group III basestocks synthetic? A: Yes, they are synthetic. Group III base oils are highly processed oils and were classified as synthetic in 1999.That year, the National Advertising Division (NAD) of the Council of Better Business Bureaus ruled in a complaint by Mobil Oil Corp. against Castrol North America Inc. Castrol claimed its product, Syntec, was a synthetic oil even though it had used Group III base oils since 1997. The ruling by NAD said Castrol presented evidence that constitutes a reasonable basis for the claim that Syntec, a Group III based formulation, is synthetic motor oil."
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 03-23-2009 at 12:07 PM. |
#17 |
![]() ![]() ![]() Drives: 2008 Yaris 5 speed HB Join Date: Oct 2008
I use the Mobil 1 0W20 in the winter and 0W30 the rest of the year.
No ill effects after 22K miles in 2008 LB with manual trans. In a '76 Civic I did put a rod through the aluminum block, but that was due to a defective head gasket from the factory. If you are changing your oil and filter at every 5K (or earlier) you should be fine with the Mobil 1. Skipping an oil change, or failing to notice steady engine leaks will be much more dangerous to your engine than altering which brand or viscosity you do happen to put in. |
#18 | |
A woman that knows her oil! What a catch!
