![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Go to the station and put the diesel nozzle in your gas filler and you will see very quickly how impossible it is to pump any diesel gas into your car,the only way i can see is if some one ran out of gas and filled it with a jerry can.
You said your sister was driving when this happened?what does she say? as the car would have started running bad almost immediately,That reciept you found may not be for a fill up of your car. |
Sure, they read and reset it, but a code can have multiple causes. Based on them knowing the original cause, they may be just assuming what the current issue is.
![]() ![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
WHAT LIGHT IS ON? THE "CHECK ENGINE" LIGHT OR THE "MAINTENCE REQUIRED" LIGHT? THESE ARE 2 SEPERATE LIGHTS AND HAVE 2 DIFFERENT MEANINGS.
#5 | |
![]() ![]() Drives: 2007 toyota yaris Join Date: Mar 2009
MALFUNCTION INDICATOR LAMP *1 |
So Im assuming it was the oil change reminder light that came on and not the engine light.
Drives: 2007 Yaris Hatchback Join Date: Oct 2008
A friend of my daughter filled her 2008 Yaris HB with Diesel. It of course stalled 1 mile from the gas station. Towed to Toyota stealership. They said $800 to fix it. She called me. I told the service writer Bool Sheet Thieves. I suggest to the girl that she should ask them to (1) flush out the fuel lines, empty tank, change charcoal emissions box, change spark plugs, clean O2 sensors (both of them). And they did that and the car works perfectly. That was 2 months ago. After the first week, the car was throwing P0420 codes, then after the first week and up to today, no more codes thrown. This code had to do with "low threshold flow to catalytic converter". This problem work it's way out over time. The total cost was $380.00. Hope this helps...by the way, why fill up your tank with premium....does not make any sense!
#8 | |
"Toyota stealership" - think i will add that to www.urbandictionary.com also for anyone wondering what the update or status is on all this. i took to autozone to have them read the computer or do whatever but they told me they no longer due that due to a lawsuit. dont know if its for all autozones or just this one in covina,ca. told me to take to aamco. maybe i'll do that tomorrow |
I will update as i go. but for now. i got my code reader. of course car had to be used something. anyway, dont know if there are more errors but the first thing that popped up was code P0420
- installing pc software.... p.s - thanks for all the blunt, honest, some funny and a couple mean replys. only kidding. i'll update later |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
1) Make sure the airbox is together properly. Shouldnt have sprayed ether in there!! This aint the sixties - yur MAF is in there. 2) I would guess that after some hard driving on the interstate the code should go away after 10 Keyon/keyoffs. U Need to burn any carbon/sulphur off the o2 sensors and the cat. Get on the highway and WAIL. BTW Dont put autolites in any car. Only OEM Denso or NGK in the tOy.
P0420 - Catalyst System Efficiency Below Threshold (Bank 1)
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
1.Fried catylitic converter (from unburnt fuel sprayed into it and being heated)
2.Bad O2 -first one before cat. 3. both? The members here who are mechanics can tell you better. Edit: Why did you make a third thread??
#13 | |
if you are i guess was being impatient and was wondering if i type more info in thread then maybe more eyes will open and more clicks. i apolagize. |
#14 |
heres more info..
does this help?
#15 |
By making more threads, you are making it more inefficient. Three different replies in three different threads will get you no where.
It's easier for the people who may know something to see what others have suggested and then work off those suggestions. Do you think people will be willing to keep jumping between the three threads just to help you? Have some patiences, people have lives...
#16 | |
| ANAL THREAD VER 2.0 | dvlnblkdrs | Off-topic / Other Cars / Everything else Discussions | 238 | 08-19-2010 09:21 AM |
