I just popped mine off to take some measurements. My Eclipse AVN2210p (which is actually the radio that Toyota made this piece because of) has a wider trim ring, which is about 1" in from the face. You can see it in the picture below. The wider ring is 179mm x 97mm. The narrower section is 170mm x 94mm.
![]() The new trim piece's opening is 174mm x 100mm (6 7/8" x 3 15/16"). This is 6mm narrower than Double DIN spec, which probably explains why some HU's fit without a problem and others don't. Also, the lip of the new trim piece extends 10mm deeper than the original did (see the pic below).
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Thanks Scott. Keep me on the list. I'll try taking pics. later. I just find it a PITA to remove the trim pieces and panels to take the HU out.
Grab the vertical trim pieces low, on the outside (by the storage pockets) and pull outward. They come off much easier from bottom to top.
scott add me to the list too, its time for me to start getting a system.
It has arrived in Canada!
Will try to install tomorrow night. HU will be JVC.
I tried trimming all around the back of the trim piece. Trimmed all the way to the line on the surface where you can see where the plastic was "joined" together.
Still no go. This is the best pic. I could take of it. It's like this on both sides: ![]() I do plan on getting the new version of the P8000BT later this year. They've released new versions of most of their 2008 models already. Hopefully, they don't add the stupid faceplate on the new model. I do still want another of these DD trim pieces Scott so keep me on the list. Last edited by IsLNdbOi; 05-14-2009 at 04:54 AM. |
#7 | |
If I understand correctly, you're trimming the lip of the trim piece to make it less deep? If that is the case, how close is it depth-wise from the trim piece being able to snap on? Also, if you were able to move the HU in deeper (by re-drilling the bracket mounting holes), would that help? |
#8 | |
Not sure how close it is to being able to snap on. Didn't take that measurement. I don't think moving the HU in deeper would help. The problem is the attached ring / faceplate on the front of the HU. |
SHIT!!
It's not going to work without some jigging. Going to have to shave about a quarter of an inch off of the sides of the HU opening in the trim panel.
The manual for the P8000BT shows this for the dimensions:
Dimensions (W × H × D): D Chassis ..................... 178 mm × 100 mm × 160 mm (7 in.× 3-7/8 in.× 6-1/4 in.) Nose ........................... 170 mm × 94 mm × 8 mm (6-3/4 in.× 3-3/4 in.× 3/8 in.) I couldn't get the P8000BT in even through the front of the new trim piece. |
Reluctantly Crouched...
pm sent
...and it's in...
Ground off the positioning pins on the HU mounting brackets. Was then able to position HU further back.
#16 | |
If possible, can you post pictures of your modified mounting brackets? Which of the positioning dimples did you grind off on each bracket? So the new trim piece doesn't rest on the face frame of your head unit? If not, don't you see a gap / empty space around the face frame of your head unit (between the face frame and the trim piece)? |
#17 | |
If possible, can you take and post up a picture of the side of your HU, as well as one of the mounting bracket. I will then use those to show you what I did. The trim piece does rest on the HU. When the trim reaches the point where it snaps into place, the back side of the opening just meets up with the 'flange' on the face frame.
#18 | |
Here's a picture of the left bracket. You can see the six alignment bumps. Radio Bracket.jpg |
| Dash destroyed in electrical fire. | purpleminx | General Yaris / Vitz Discussion | 79 | 06-12-2009 03:53 PM |
| [Recovered] Group Buy for Australia #1 (Badges) | harveyjai | Australia | 9 | 12-13-2008 03:59 PM |
