Old 03-27-2009, 10:31 PM   #1
supmet
Drives: 2007 4 Door Yaris
Did you tell the mechanic you bought ADJUSTABLE camber bolts?
Also, -3.5 is farther than the bolts list they go on the microimage site. 15mm Adjustable Camber Bolts +/- 1.75 degrees. Did you hit a curb or something? You might have broken a bolt?
Old 03-27-2009, 10:35 PM   #2
MicroHB
Drives: MY HB
i did he said to contact the manufacture and i did not hit anything he blamed it on my coilovers
MicroHB is offline   Reply With Quote
Old 03-27-2009, 10:44 PM   #3
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
What incorrect instalation , .
Old 03-27-2009, 10:51 PM   #4
MicroHB
Drives: MY HB
are you saying my coilovers are installed incorrectly?
Old 03-27-2009, 10:54 PM   #5
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Sounds that way , or the guy doesn't know what he is doing ,
ie camber bolts required to correct problem .
How soon to get alignment after TRD spring install? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 03-24-2009 09:08 AM
Dealership explains no need for alignment jmjonesey DIY / Maintenance / Service 6 04-23-2007 05:20 PM
Suspension alignment after new springs? mrrock Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 02-14-2007 02:05 PM
Front End Alignment after Spring Install? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 08-26-2006 08:46 PM
