![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
You go to the doctor and he spends like what 5 seconds looking at you. And if you didnt have insurance im sure it would be well over 100 dollars. And even if you do have insurance its still atleast 10-25 dollars.
If you came to my shop i would probally charge anywhere from 30-45 for the same service. But you would get the oem spark plugs. Then gapped to spec. Then installed with antisieze to ensure ease of removal next time. A professional job done cost money. What would you thing is a fair price to pay then? If you walked into any shop right now and asked to change thier spark plugs for you for less than 20 bucks they would just laugh at you. To them theres more liability to do the job than its worth it. |
#3 | |
There is no excuse for a $65 spark plug change. If the dealership wasn't a ripoff, people like me would go. I don't want to change my own oil, but at the same time I'm not going to pay 300% of what it costs me at home. I'd gladly pay a premium, but where do you draw the line? |
#4 | |
What kinda plugs would you put in your car for under $10?? Autolites?
When I'm due, I'm going OEM.
Never take eyes off opponent - Bruce Lee |
#6 | |
http://shop.advanceautoparts.com/web...=0&pageSize=20 |
![]() Drives: 2007 Black LB Join Date: Nov 2008
It's a total rip.... no matter how you try to justify it.
![]() ![]() ![]() Drives: Yaris Hatch /Landrover D2 Join Date: Jun 2007
The part I like is "re-set computer" must be to justify the spark plug labour, I dont recall needing to re-set the computer to change plugs. The invoice should have said " change plugs re-set cash register".
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
it's called flat rate. the shop charges a flat rate per hour; no if's and's or but's. could the shop have eaten the charge yes. would that have made a better impression on the customer and all of you? yes. would the customer return? yes. it's just what makes the world go around, economics, competition.
Besides, La_scanner I'd really think it'd best if you could move on from recycling the same thread over and over again, please :)?
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
well, the main differance between normal, platinum, and iridium plugs, is how long they will last. most spark plugs will work in any car well as long as the gap and firing temperature are somewhat the same as the stock ones. a standard cheap-o spark plug will not last near as long as a quality platinum plug...some junky plugs will only make it to 10k or 20k miles before they start causing missfires, where as a platinum plug of decent quality normally makes it 100k+ miles.
and in regards to if shops charge to much to fix your car...if its such a rip off do it yourself. I have worked in shops for years...you are paying for experience and a warranty. if its easy work, do it yourself and take the risk of breaking things then bringing it to the shop to fix what you screwed up. i have sliced my fingers open many times before, and if i can i will stitch, glue, or tape the wound closed and hope for the best. if its really bad i will have to go to the hospital to have then stitch it closed. they ussually charge $500 just to have it looked at and a quick stitch up job...taking them less than an hour for the whole process. $500+ for 1 hour of labor and a few cents work of dis infectant, thread, and a glorified bandaid. one could argue that i am getting raped...i argue that while it sucks, i am paying someone with YEARS of experience to ensure that i dont end up with a scar, or a infection, loss of movement, or dead from blood loss. look, everything is a rip off...someone has to get paid. automotive industry is the same. i have worked retail jobs too...they will charge you $100 for a product they bought for $12. get used to it. and no, that is not the most expensive spark plug replacement i have seen.
#11 | |
Half a Bubble Off Plumb
Changing plugs in these is easy. When my daughter's Echo started setting misfiring codes, I fixed it by putting in a set of ordinary Autolite plugs. (I choked when I saw the prices for platinum and iridium plugs!) The fancy plugs don't affect how the engine runs, they just last a long time. At the time I didn't have any idea I was going to trade the car off soon, but normal plugs will last 30,000 miles or so. They're easy to change, like I said, so very long life plugs aren't a big advantage to me. It's a much bigger PITA to change plugs in the Nissan VG30E in my Villager van, but I put standard Autolites in it, too. Not that big a deal.
![]() ![]() Drives: 2007 toyota yaris Join Date: Mar 2009
just want to let everyone know that toyota is waiting on the catalytic converter to arrive. then they will replace. under warranty. everyone's happy again. yay!
-Jameson |
#14 |
Thast the one good thing about california. Since they are super strict on emissions emissions components are always warrentied. I had a honda civic that came into my shop that was a 99 i think that had 94k miles. His car was running a little rough. Turns out there is a extended emissions warrenty on his vehicle. That covers his o2 sensor since the check engine light was on. Also they had to perform a full tune up. new cap rotor wires and plugs. At no charge to customer all under a extended warrenty. The guy was estatic cause he just bought the vehicle a week ago.
#15 |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
hey, i can get NGK's from autozone or o'rileys...and they're only 3 bux each...i have a 10mm socket and a spark plug socket, and an extension and a 3/8" ratchet...anti-seize for 99c when i pick up the plugs...
the car has coil per cylinder so i dont need wires...and there's no coil...or pickup, or distributor, or timing to do...i'm banking for 15 bux. now, on to the dealership issue. i worked at a shop, it was toyota/gmc. now the shop was busy for the most part, always had cars in there, and the shop rate was 89/hr. with that being sed with 4 mechanics we still lost 75k per week. just the mechanic's shop, not including parts, not including sales, not including paychecks or electric or rent or insurance or porters or anything else..........just maintenance shop. so i'm on both sides of the table and i'm doing just fine with both of them. i'm toyota certified and i think i can handle a spark plug change. specially when u can do a SBC in a vette in 20 min, or a 5.4l triton piece of crap in about 30....any way i banked on plug/wire changes for the dealership. when they charge 1.5hrs for an plug change and i'm gettin paid 1.5hrs for a 30 min job...i'm happy. |
