Old 03-29-2009, 01:50 PM   #11
changchewsoon
Drives: Vios Turbo
Send a message via MSN to changchewsoon Send a message via Yahoo to changchewsoon
Hi,
I hope its OK for me to post here although I'm running a boosted Vios rather then a charged one, I have a Greddy Informeter Touch which plugs in to the OBDII connector to monitor all engine parameters, and I've also got a Innovate LC-1 Wideband O2 to monitor my air/fuel ratio.
I just want to share with everyone that by using E-Manage Blue, my tuner is able to get the ECU to run at a constant A/F ratio of 12 during WOT and a AF ratio of 14 during close loop. My wideband O2 display confirms this.
I'm currently using the base + ignition + injector harness for the E-Manage.
Hope the dyno chart is able to provide a better idea, hope it helps.
Please do not hesitate to ask me if you need any information, I'll try my best to share.
http://4.bp.blogspot.com/_RQcAxTVtNR...Dyno-Chart.JPG
454 whp, 1.7 bar boost, pump gas, water/meth.
501 whp, 2.2 bar boost, pump gas + avgas, no water/meth.
www.viosturbo.com - World's first 500 WHP 1NZ-FE
changchewsoon is offline   Reply With Quote
AFR running extra rich at WOT? eTiMaGo Performance Modifications 15 03-10-2007 12:10 PM
