Quick and easy and cheap way to fix your problem.
Step 1 Let your car warm up to full operating temperature. Then roll down your windows and turn your heater on max hot for about 10 minutes full blast. Make sure its set to outside air. Once done go ahead and turn the heat down. Step 2 Purchase a bottle of febreeze anti microbial spray. Spray as much as you can handle in the vent area which is located near the wiper blades. With the blower motor on it will suck down the febreeze through the vent system killing any remaining bacteria growing inside you ac duct system. Also giving you a nice fresh smell inside when you turn it on now =) Step 3 enjoy your now nicely smelling car. Explination: The high temperature heat kills most of the bacteria in the lower vent areas whiping out the nasty smell. The febreeze ani microbial does just like it says killing the upper bacteria of the vents while helping instantly removing odors. |
