Old 04-05-2009, 07:43 PM   #1
OK Yaris
Drives: 2007 Liftback
If the Autolite plugs installed in your car were the XP3924 you mentioned in one of your other threads, then you had the correct replacement plug specified for your vehicle. Not the OEM brand, but they should have worked just fine, without damaging other components of the vehicle.
And the diesel could not have fried a coil.
OK Yaris is offline   Reply With Quote
Old 04-05-2009, 08:15 PM   #2
la_scanner
Drives: 2007 toyota yaris
Yes. those were the ones that were installed.
SCORE
MECHANIC - 1
ME - 1
la_scanner is offline   Reply With Quote
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 09:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 12:08 PM
FS: OEM NGK Spark Plugs mikenacarato Items for Sale by private party 13 01-23-2009 05:05 PM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 09:38 PM
