Old 04-05-2009, 11:49 PM   #1
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
The Denso plugs have an Iridium tip which can last for 100,000 miles. That is why they cost so much. So long as the tips aren't broken or damaged, they should be usable with the proper gap. You need to find a mechanic that will diagnose your problem.
Old 04-06-2009, 10:51 AM   #2
TheSilkySmooth
TheSilkySmooth's Avatar
Drives: 08 3DR 5M Bayou Blue; 09 Fos
Sometimes if you glaze over the plugg insulator tip it will short to the nut and start misfiring. Only way out is to replace. This is usually caused by some oil fouling, then hard operation. The metals in the oils plate out on the insulator and then its no longer an insulator - its a resistor. -
I agree with you that the OP needs a good mech to diagnose his probs. Now where can he find a good mech .... Any recs from guys around where the OP dwells?
TheSilkySmooth is offline   Reply With Quote
Where do I buy ngk iridium tip 7 heat spark plugs? PETERPOOP Performance Modifications 23 03-08-2009 09:34 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 02:53 PM
Dual ground electrode spark plugs Kitt DIY / Maintenance / Service 15 02-09-2009 12:08 PM
FS: OEM NGK Spark Plugs mikenacarato Items for Sale by private party 13 01-23-2009 05:05 PM
Spark Plugs YamilR DIY / Maintenance / Service 2 09-28-2007 09:38 PM
