![]() Drives: 2001 silver Yaris Join Date: Dec 2011
![]() Drives: 09 hatchback Join Date: Dec 2008
'09 yaris. 155k when it sputtered and died. Used headlighta whenever I drove.
![]() ![]() Drives: Want a yaris Join Date: May 2012
08 yaris with 96k miles. Stock battery cranks the starter slower this winter than last winter. Hope it gets me though and I'll replace it next fall. If not, I can't complain about it.
![]() ![]() Drives: 2007 4dr sedan Join Date: Jun 2009
Mine lasted 7 years at 66,000Kms. Just had it changed yesterday.
Funny thing. I called the dealer parts department about a replacement and was told the price was $142 plus tax. He then told me that if I had it replaced there it would be $107 plus $18 labour plus tax. Guess who did the replacement. |
Toyota dealers in Quebec does not offer the Panasonic battery. It's a battery made in Canada if i remember.
Either.. my oct-06 Yaris is still on original battery at 136000km. |
![]() Drives: 2010 3 dr hb Join Date: Nov 2009
I have a 2010 3 door HB and mine only lasted until this year. It died after a temperature drop at night. So lasted 3 years. i bought an Optima yellow tp
Just thought I would pass along this tidbit of information....might be helpful for people (not me
) who make Costco part of their lives. This comes from the Phoenix, Arizona forum (not the Automotive forum) at city-data.com. Rather than testing a battery under warranty to see if your claim/issue has merit, apparently Costco takes your word for it and issues a refund. I imagine nearly all customers then apply the refund toward a new battery. I don't like Costco, but I have to admit this is a good policy.
![]() ![]() Drives: yaris sedan 09 Join Date: Jan 2010
Oem battery for now with 166k km ( 101 000miles)
Yaris 08 Temperature is -29c or -21f |
Just replaced the original battery on my 05 Echo, it still had enough power to barely start the car, thought i'd change it now while i can still drive to the battery store.
Have Yaris will travel.. |
The Battery Guru
Drives: 08 2-door hatchback 5-speed Join Date: Dec 2013
Hey all, I sell batteries for a living so I should chime in to provide some propper battery facts. First, batteries need to be maintained. This means that you need to check and keep your fluid levels topped up (if you have a maintenance battery) to the propper level. the plates inside the battery should never be exposed to air. Exposing the plates to air will increase the rate of sulfation in the battery, thereby breaking the battery down physically. The propper fill level is to the base of the cone when you remove the cap, this is usually about 3/4" down. Use only distilled water and use gloves to protect your skin (acid on the skin feels itchy and sticky, it's a slow breakdown since it's diluted sulfuric acid).
2nd, if you want to get the most life out of your battery you must use it and never let it drop below 12.2 volts. 12.6-12.8v is considered a full charge, while 12.2 is fully discharged. At 11.8v the battery is sulfating at an accellerated rate. If your battery is ever this low this means 1 of 4 things. 1; your alternator isn't working proppery. 2; You aren't driving far/fast enough the keep your battery fully charged. 3; Something is drawing power when the vehicle is off (typically a door left slightly open). 4; the battery is just plain worn out. The average lifespan of a car battery when propperly used and maintained is 5-7 years. Some people see as much as 11 years (I have customers come in all the time with decade old batteries that are just now starting to get too weak). Defects do happen, but more times than not the battery just needs a good propper slow charge and a desulfation (some special automatic chargers have this option like the CTEK's and Genius's). Good battery stores should have a load tester to tell you what the health of your battery is. At our stores we use 2 different testers. We have a portable tester we call the toaster, and we have a $1000 carbon pile load tester (more accurate results). The battery must be at atleast 12.6v in order to be tested. You can have a battery with 12.6v and have extremely low (less than 100 CCA's) Cold Cranking Amps. Batteries are a chemical reaction that produce energy. As such you must remember a couple things. Letting a battery sit for extended periods of time (longer than 3 weeks) without being proppery charged (either through driving or through a propper charger at a slow rate of 2 amps or less) can kill a battery. To get they most life out of your battery you must use it. I tell all my customers that don't drive their vehicles much that they need to take their vehicle for a good drive of atleast 15 minutes at freeway speeds to recharge their battery (this is also good for the health of the motor). Batteries naturally lose voltage over time through the chemical reaction, which is why you need to keep it recharged. For all you old timers who think you can just shock a battery with 100A for 10 minutes, good luck. Most likely you will cook your battery and possibly blow it up (seen it too many times). Over charging a battery is not only bad for your battery, it is dangerous. I have seen many customers come in with what's left of their battery in a 5-gallon bucket because they left it on a charger at 20+ amps for a few hours. As a professional I may use high amperage to waken batteries or bring their voltage up enough for an automatic charger to take over, but I only do so for very short amounts of time and am monitoring the voltage of the battery very often. Any other questions on batteries of any kind please feel free to ask. If ya'll want to know about the AGM batteries I can go into detail on those as well. |
![]() Drives: 2008,Sedan Join Date: Dec 2013
Hello , I have recently bought a Yaris 2008, the day after I bought the car ,battery was dead ,It was a Panasonic original battery . It was lasted 5 years.
meow
Drives: Yaris Sedan, Black Sand Pearl Join Date: Jun 2006
My 2007 Yaris Sedan (purchased June 2006, built in April 2006) just had the factory installed battery die this past weekend. Since the weather has been cold I've been remote starting it (after market) so I wouldn't know if it was struggling to start. I think 7.5 years was a good run.
I'm going to get the Napa Legend as recommended. |
Embracing Curves
Drives: '14 Prius Executive Join Date: Aug 2013
My battery seems to be the original one and if that's true, it's 4 years old and has no problem with cranking at all.
I'm curious how the flow heater I'm going to integrate (controllable via PWM, theoretically up to 250A, but I don't want to blow the alternator fuse nor one of its rectifiers, so I'll run it at about 110A) will affect the remaining lifetime :D |
#16 | |
#17 | |
Embracing Curves
I knew that
Well, mine is from a BMW e46 and heats the water. In first tests, it got the water temperature up by 40K within about a minute But Quote:
![]() Well, this is a bit less than what I expected. Just for reference: My Battery is a 60Ah one which is stated to be suitable for start/stop needs. Since I use a µC (PIC32) which reads from the two CAN buses (yup, there are two on mine which has a separate alternator controller), my plan was to rise the heater power (via the PWM duty cycle) until the alternator load resp. its excitation duty cycle (ID 1c8, 4th byte, on the separate bus) exceeds a value I'll have to find out. I'll add some other functions, too, but that would be way off topic here - PN me if you are curious, I won't keep the source code for me ;) |
meow
Oh it's not my battery like I thought. It's bad gas or condensation. My fiancé got it to start after dumping Iso Heet in it. I am still wanting to get a new battery. I would hate for it to just up and die.
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| DIY: Braille Battery install | texkid | DIY / Maintenance / Service | 39 | 02-19-2013 02:40 PM |
| Keep your vehicle protected! | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 17 | 09-10-2009 02:02 AM |
| Lightweight battery install | Klink10 | DIY / Maintenance / Service | 11 | 02-28-2009 08:43 PM |
| Will putting new lowering springs damage original shock absorbers in the long run? | Joel Leong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 06-07-2006 08:30 AM |
