I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
The more I read, the less i want to do this lol Maybe if someone does it and gets it right with a good diy...
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
My R1 eats my Vitz!!
Drives: '07 Vitz Lifty, Stick Shift Join Date: May 2007
That's what I'm saying now :) I might wait and finish after someone smarter than me does it and includes nice pics to follow haha!
My Car Rules! |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Ditto for me. I have the 09 and bought the OEM stalk, but mine's a 5 spd. so I'm worried about the clutch switch install
Oh, and the white that you jumper the clutch switch wire to is indeed the one I meant, so you're OK there...
Ok i see that now that I look at the pic. You had one more white one in with the brown one huh? And I see I was looking at the wrong side of the connector...duh. Anyway I'm gunna try that other pin in the ecm and try again tomorrow. Thanks a lot we'll see what happens :)
My Car Rules! Last edited by nickhjort; 05-03-2009 at 08:50 PM. |
#6 | |
I was just tracing the 7.5A IGN fuse and I think that the pin you are on, on the ECM, is hot, so when you hit the switch it grounded it and popped the fuse, as that fuse feeds parts of the ECM. By the way, before you road test with the correct pin, try the ON button in the driveway to be safe. I can hit the on with the ignition on and engine off and the cruise light comes on. Obviously you won't be able to tell if cruise is actually working, but at least you'll know if you pop a fuse. |
Awesome! I'll design a circuit for the LED. It will probably require changing the on/of switch to a DPDT switch, as the LED circuit will have to be controlled by the switch, rather than the ECM.
You don't think the wires going to the speedo and stuff has the cruise wire in it even though I don't have cruise indicator...? That would be much easier :)
My Car Rules! |
#10 | |
The only possibility that I can see is that the microcontroller appears to drive all of the status LEDs via a 4-bit multiplexer. It is possible that the micro is programed to support the LED, but has not connection to it. If you want to disassemble your meter and take some pictures of the PCB I can take a look. |
I can take some pics tomorrow. You need the back or front of the circuit board? I might see how hard it's gunna be to change the led's while I'm at it. Change the colors of my speedo and stuff.
My Car Rules! |
Both sides if you can get at them. If not, some good macros of the IC's so I can figure out what they are and the pinouts of them.
Damn, thanks for doing all this $hit man. I'll get the pics for ya tomorrow.
My Car Rules! |
![]() ![]() ![]() ![]() Drives: 2008 meteorite hatchback Join Date: Nov 2008
Alright, so to make the OEM stalk work, how would it be different than what nickhjort is doing?
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
What about the extra wires I need? Any particular gauge or material?
Also - would I go about threading the wires through the steering wheel via the clockspring wiring? And on the stalk, which wire is which? I have a lot of questions because the majority of this thread was about adding buttons for cruise control, and the stalk was only talked about at the very beginning.
#17 | |
I would go with somewhere between 18 and 22 gauge. Insulation material is not critical. The wires are already in the clockspring, so you will just plug in the stalk connector when you pull off the steering wheel. On the other end of the spiral cable (at the connector shown below, next to the yellow one) you don't have the blue and brown wires in pins 1 (blue) and 3 (brown), so you will either have to find pins that fit, or solder the wires right to the connector's pins.
I'm definitely missing something. Where do the additional 2 wires from D3 go? I mean, with the switch method for models other than the 09, it seems like you don't need to use D3. But since I'm going to be using the stalk, I need to use D3.
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
