Old 01-15-2011, 12:46 PM   #1
teddy
Drives: 2008 5-door hatchback
Send a message via MSN to teddy
How is everyone running the wire from D3 to the ECM connector A21?
Last night I tried to follow the conduit of wires running from the ECM in the engine bay without much luck. I didn't want to have to rip apart the engine bay to find out where it goes. I really feel like I'm missing something silly!
teddy is offline   Reply With Quote
Old 01-15-2011, 01:29 PM   #2
The easiest way is to enter the rubber grommet above the ECM or the one below it (which is actually the grommet around the AC drain hose). Then, once you are through the firewall on the passenger side, you can bring the wire across to the driver's side.
Old 03-14-2011, 03:14 PM   #3
mgoldhawk
Drives: 2001 Toyota Yaris
Would I be able to fit cruise control to my Yaris using the same method? I have a 2001 5door hatchback...
mgoldhawk is offline   Reply With Quote
Old 03-14-2011, 03:28 PM   #4
No. 1999-2005 Yaris used a cable throttle, rather than an electronic one like 2006 and newer ones have. So, 1st gen Yaris require an electro-mechanical cruise control system.
Old 11-09-2015, 11:17 PM   #5
Paulee
Drives: 09 yaris s five dr stick
U got a hatch or sedan? Next chance i get i check for the plug
Paulee is offline   Reply With Quote
Old 11-09-2015, 11:17 PM   #6
Secretblend
Drives: 2009 Yaris
Sedan.
Secretblend is offline   Reply With Quote
Old 12-06-2015, 10:04 PM   #7
Paulee
got my CC installed today and loving it. Best $20 I spent. Still haven't got the clutch switch kit yet so had to jump the connector for it to work and yes, the revs jump when u step on the clutch with the cruise set. overall pretty simple install tho.
Old 07-22-2017, 02:57 PM   #8
mumairr
Drives: Toyota Vitz 2010
My Vitz 2010 model already has wiring upto ECM (saw it by removing the cover behind the steering )but my cluster doesn't have any indicators for CC. Do you think if i install OEM CC, my car would be able to handle it? irrespective of the indication on the cluster? if this is the case, i might change my insturmenet cluster.
mumairr is offline   Reply With Quote
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
