Old 04-20-2009, 05:08 PM   #1
1stToyota
1stToyota's Avatar
You're still confused
Originally Posted by SilverGlow View Post
You have the same confusion (misunderstanding) that many have in regards to 0w-20 and 5w20.
The fact is, the ONLY difference is that the 0w protects better during very cold weather during start ups. As to operational oil temperatures (180f to 212f and above) the 5w and 0w both protect the same because they are both 20 weight on the high end of the viscosity range.
So at hot operational temperatures, 0w-20 and 5w-20 provide the same protection.
If that is so, that they offer the same protection, then why does Toyota's TSB absolutely refuse to list "0w-20" as a suitable viscosity for the Yaris engine, yet they have no problem with saying that "5w-20" IS okay for our Yaris? And before you say it's okay because Amsoil says it's okay, when Toyota says not okay, remember that Amsoil does NOT offer an API approved 0w-20...you'd have to go the XL 5w-20 or XL 5w-30 to get an API approved oil to keep from voiding warranties.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-23-2009, 03:25 PM   #2
SilverGlow
Drives: 2007 Yaris Hatchback
You are very, very confused. The reason toyota does that has NOTHING to do with 0w and 5w. The reason is the differences in additive packages. For example, I would not put any 0w-20 in my Yaris, however I would put in AMSoil 0w-20 and Mobil1 0w-20, but not others.
It's about the additive packages, and not the viscosity. Now as time goes on, more 0w-20 brands will be good for the Yaris, but today not all.
SilverGlow is offline   Reply With Quote
Old 04-24-2009, 08:41 AM   #3
1stToyota
1stToyota's Avatar
Toyota (USA) Demands API approval
Link?
Show me where Toyota says do NOT use 0w-20 because of additive packages, but use 5w-20 and 5w-30 for the Yaris (1NZ-FE) because their additive packages pown 0w-20's...all I see in Toyota's TSB is that they will allow 5w-20 but NOT 0w-20 in the Yaris motor, and there have never been little footnotes about *additive packages* as far as I can tell, plus you've ALWAYS stated that the TSB states 5w-20 is okay, so "with that being said 0w-20 is okay because it performs exactly like 5w-20" without ever mentioning certain additive packages in certain oil brands being the deciding factor.
And why would you use Amsoil 0w-20? It's not API approved...hmmmm...but the Amsoil XL 5w-20 is API approved ...bet that's another reason why the Toyota TSB says yes to 5w-20 and no to 0w-20. Bottom line: Until the TSB says yes to 0w-20 it's wrong to use it, but keep using it year round in southern California.
You must wake up in a new world every day. How many times have you claimed that brand doesn't matter, that the cheapest discount synthetic will make an engine last just as long as an expensive synthetic, like Royal Purple? I'm not the one that's confused; I use API certified oil, and the proper viscosity, you don't.
2008 Scion xD
Old 04-24-2009, 01:40 PM   #4
SilverGlow
Link?
You want a link? Go to AMSoil's web site. Go to Mobil1's website. You can run BOTH 0w-20's in your Yaris with absolute confidence. So why theirs and not others 0w-20?
ADDITIVE PACKAGE.
For example, this is why SL grade 5w-30 can be run in car X but not car Y, yet BOTH cars call for 5w-30, but not ANY 5w-30.
So if two oils are 5w-30 yet only one can be run in car X, why?
ADDITIVE PACKAGE differences.
There are cars out there that call for a particular brand of 5w-30 or 5w-20 or 0w-20 because not any brand will do even if the viscosity range is perfect....why? Additive package differences, again.
Old 04-24-2009, 02:42 PM   #5
1stToyota
1stToyota's Avatar
You want a link?
Don't backup now...you said Toyota will allow 5w-20 but not all 0w-20's because of an additive package issue. LOL!
To find a non API approved listing? No.
To see them disagree with Toyota's TSB? No.
Wrong. Not listed as approved by Toyota, AMSOIL 0w-20 is not API certified.
Why you but not Toyota?
ADDITIVE PACKAGE.
ANY car that calls for SL 5w-30 can run ANY brand of SL 5w-30.
If Toyota says 5w-20 for your Y than why do you run 0w-20 when their TSB says it's only for their X?
Right back to you saying that Toyota's TSB allows particular brands of 0w-20 because of those special non API approved additive packages...again...proof? Or just your need and not Toyota's need, again?
2008 Scion xD
Old 04-24-2009, 01:48 PM   #6
SilverGlow
Link?
I've said it many times and I will say it again: BRAND DOES NOT MATTER.
However this thread is about 0w-20 vs. 5w-20. In regard to this particular and specific issue, brand does in fact matter because not all brands provide the appropriate additive packages required by certain cars.
Now if one wants to use oils found in their manuals/TSBs (5w-20, 5w-30) in their Yaris then as long as the oil is either made by AMSoil or is API-SM certified, then BRAND DOES NOT MATTER.
For example, when I run 5w30 or 5w-20 the brand of the synthetic does not matter. But for 0w-20 the only brands I will use are Mobile1 and AMSoil. This is the EXCEPTION, and not the rule.
Hope this clarifies.
Old 04-24-2009, 02:50 PM   #7
1stToyota
1stToyota's Avatar
It does
I've never seen you make viscosity distinctions until now, when I called you on it.
And they have to have the appropriate additive packages to even produce a 0w-20 viscosity, fyi.
And as in certain cars, our 1NZ-FE Yaris? Still haven't seen where Toyota lists 0w-20 for it yet.
And, again, stick to that lose/lose formula of:
1) Use an Amsoil grade that isn't API approved
2) Use a viscosity that isn't listed on Toyota's TSB
2008 Scion xD
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Synthetic Oil Kaotic Lazagna DIY / Maintenance / Service 122 09-20-2007 03:40 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
