Old 04-21-2009, 05:54 AM   #1
IsLNdbOi
IsLNdbOi's Avatar
Part #s for Fog Light install? Can anyone who works for Toyota confirm?
I would like to install fog lights on my '09 5-door LB, but need to find all the correct parts.
I've searched and have found different part numbers for each part I need.
Can anyone here who works for Toyota confirm each part number is correct for the '09 5-door LB?
New headlight stalk w/ fog light switch (combination switch):
84140-52151
Fog Light Relay:
90987-02027 ?
or
90987-02012 ?
Fog Light Shroud (Left):
81482-52260 ?
or
81482-52250 ?
Fog Light Shroud (Right):
81482-52330 ?
or
81481-52320 ?
Old 04-21-2009, 06:58 AM   #2
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
If you want to save some cion talk to Garm at microimage ,
he is now selling his kit's with the correct relay + the wiring to plug into
the relay box under the bonnet.
all you will need then is the stalk , because if i am correct the 08 sedan foglights are the same as the 09 L/B.
Left: 81482-52250
Right: 81481-52320
Old 04-21-2009, 07:05 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
I'd still need the fog light shrouds since his kit is specifically for the 06-08 LB. The '09s have changed a little bit. Some wiring is different (ex. tail lights, aux jack, etc.) and the fog light shrouds are different.
That's why I'm asking if anyone who works for Toyota could check for me. I could buy a fog light kit for the lights then get the correct parts from Toyota Parts Cheap.
Old 04-21-2009, 07:40 AM   #4
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
The fog light shrouds are the same as the 08 Sedan ,from what i have seen .
Old 04-21-2009, 08:04 AM   #5
IsLNdbOi
IsLNdbOi's Avatar
I'd still like to have the part numbers for the parts meant for the '09 LB.
Old 04-21-2009, 10:45 AM   #6
spookz
JDM yO!
Drives: '09 3dr. 5-spd
They appear to be the same shape at a glance with the 08 sedans but when looking into closer detail, I believe they're different.
I can try and check for you if you are able to hold until the end of this week..
Old 04-21-2009, 12:47 PM   #7
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
STALK: 84140-52151
RELAY: 90080-87026
SHROUD LH: 81482-52260
SHROUD RH: 81481-52330
Old 04-21-2009, 01:50 PM   #8
DerFlosser
DerFlosser's Avatar
Drives: Yaris
STALK: 84140-52150
RELAY: 90080-87026
Stalk p/n is wrong. It should be 84140-52151 (08+)
DerFlosser is offline   Reply With Quote
Old 04-21-2009, 02:14 PM   #9
BLAZINBLUEVITZ
fixed......
Old 04-22-2009, 10:00 AM   #10
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Also,
Are you positive that these are the 09' shroud p/n's? Thanks in advance!
Old 04-22-2009, 12:54 PM   #11
Also,
He's correct - I just got my set from my dealer:
Old 04-22-2009, 01:13 PM   #12
MGargano
Drives: 2009 Yaris Hatchback
Which fog kit are you using for your '09?
MGargano is offline   Reply With Quote
Old 04-22-2009, 01:15 PM   #13
The Microimage one.
Old 09-27-2010, 01:04 PM   #14
mari
Drives: 2010 sedan
STALK: 84140-52151
RELAY: 90080-87026
I want foglights on my 2010 Sedan, and want to confirm these part numbers are also valid for my car.
Oh, and is there an OEM toyota part number for the foglight wiring harness? I assume that with the new foglight stalk, there is no need for an interior wiring harness.
mari is offline   Reply With Quote
Old 09-27-2010, 05:50 PM   #15
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Ifyou get the latest kit from Micro Image (a sponsor of this site )
everything is in the kit apart from the OEM Stalk
which is not required , and the whole kit is nplug and play
Old 04-21-2009, 03:13 PM   #16
Lafiro
Drives: 06 Yaris Sedan
What about for an 07 sedan?
Thanks.
Old 04-21-2009, 04:31 PM   #17
IsLNdbOi
IsLNdbOi's Avatar
Thanks guys. BlazinBlue, is this what is shown on Toyota's official parts list?
Old 04-21-2009, 04:33 PM   #18
BLAZINBLUEVITZ
yes
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 02:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 07:46 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 03:04 AM
