Old 04-21-2009, 10:00 PM   #1
YAR1S
YAR1S's Avatar
If I remove emblems, will shadow be left behind?
question answered.
YES an 07 will leave behind shadows :[[[[
oh well the vitz covered up the toyota shadow just got to get something for the other side now ....
anyways heres some eye candy.
-Jen <3
Old 04-21-2009, 10:08 PM   #2
SIPNGAS
I LOVE my Yaris!
SIPNGAS's Avatar
Drives: 2007 Polar White LB
nope...I don't think so. If the car was a few years older, maybe but I think you'll be fine.
Lisa
aka SIPNGAS
Old 04-21-2009, 10:13 PM   #3
supmet
Drives: 2007 4 Door Yaris
I was thinking the same thing...
And worse case scenario take one off and you can just put it back on with less than 5 dollars worth of 3M tape.
Old 04-21-2009, 10:12 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
Will probably be just fine.
BTW, the NETZ emblem doesn't really belong on the rear hatch.
Old 04-21-2009, 11:04 PM   #5
YAR1S
YAR1S's Avatar
i know
just want a differnt look
i like the netz emblem better.
plus it gets some stares.
-Jen <3
Old 04-21-2009, 11:19 PM   #6
auxmike
auxmike's Avatar
i know
I had a coworker ask me about the "propeller" grill emblem!
Old 04-22-2009, 06:43 PM   #7
YAR1S
YAR1S's Avatar
haha nice :D
-Jen <3
Old 04-21-2009, 10:14 PM   #8
Go Netz! Get rid of the cowboy, yeehaaaaw
Old 04-21-2009, 11:39 PM   #9
cfiimei
Drives: Sedan
I have a friend that found Pinto emblems and put them on his. Really freaks people out!
cfiimei is offline   Reply With Quote
Old 04-24-2009, 12:43 PM   #10
eric81
eric81's Avatar
Drives: Toyota Salesman
I shaved my emblems at home, and all it really is fairly easy. Make sure it's a warm or hot sunny day. You need a flat razor to help scrape the badges away without killing the paint, and some sort of cleaning solution (dish soap and a slightly rough rag to ensure no ugly lines are left over after taking the emblems off). Simply peel the emblems off, if they persist to be stuck, slowly and gently use the razor to help peel it away from the car. The T emblem (Toyota symbol) is stuck on the car with two studs as well as 3-M tape. Don't remove unless you have a filler or replacement emblem.
eric81 is offline   Reply With Quote
Old 04-24-2009, 12:56 PM   #11
mrbond
mrbond's Avatar
I used fishing line and a hair dryer and it worked wonderfully. Heated it up with the hair dryer, used the fishing line, and everything came off in about three minutes, then I cleaned off the remaining residue with windex, and voila! No shadow, no badge! I personally wouldn't recommend using razors if there's something a bit safer to use.
- A Toyota Yaris
- A whut Yaris?
Old 04-24-2009, 12:57 PM   #12
WolfWings
WolfWings's Avatar
Drives: Silver 2007 3Dr - Gryph
Far, FAR, *FAR* easier way to remove the badges than a sharp blade and risking scratching your paint: Just grab some dental floss or fishing line, 'saw' through the goo/tape holding them to your car, just simply rubbing your thumb on the leftover goop will roll it into little bits that flake off without risking that fragile paint.
WolfWings is offline   Reply With Quote
Old 04-24-2009, 01:30 PM   #13
eric81
eric81's Avatar
Didn't think about fishing line or dental floss, but deffinately a recommendation. I didn't use the razor myself because it just came right off. The soap got the little bit of dirt build up around where the tape was, and it looked perfect immedeatly and looks just as clean now. It kills me how many cops have no clue what type of car I drive. They even ask me to spell it. (Two tickets in one month and now someone broke into my car and stole some CD's (my entire collection) and broke my HD stereo trying to pry it out.)
Old 04-27-2009, 10:27 PM   #14
YAR1S
YAR1S's Avatar
bummmmp for answer to question.
-Jen <3
Old 04-27-2009, 11:09 PM   #15
eric81
eric81's Avatar
Answer: No, not if done correctly. Wash area WELL before and after, and it should be fine.
Old 04-27-2009, 11:15 PM   #16
YAR1S
YAR1S's Avatar
LOL wow....
yeah I definately tried that.
I got the emblems off ...
got the 3m tape goo off .
got the black outlining off with alcohol pads
finished up with some goo gone...
there is a definate color difference.
I'll take a picture tomorrow in the sun.
-Jen <3
Old 04-27-2009, 11:21 PM   #17
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Leave that area (wax around that area) unwaxed for about a month . Give your car time to "tan" Well actually "fade"
Old 04-27-2009, 11:22 PM   #18
YAR1S
YAR1S's Avatar
haha yeah i guess i could try that
-Jen <3
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
DIY : How to remove door panels FEINT DIY / Maintenance / Service 13 11-18-2021 03:16 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 01:59 PM
DIY: Debadge/Black out Emblems TinyGiant DIY / Maintenance / Service 113 08-02-2014 03:44 PM
