Old 04-22-2009, 12:13 PM   #1
MGargano
Drives: 2009 Yaris Hatchback
He's correct - I just got my set from my dealer:
Which fog kit are you using for your '09?
MGargano is offline   Reply With Quote
Old 04-22-2009, 12:15 PM   #2
The Microimage one.
Old 04-22-2009, 12:28 PM   #3
MGargano
The Microimage one.
That's what I figured. Is it this one? http://shop.microimageonline.com/pro...&productId=111
Will this kit work with the '09 3 door LB if I get the shrouds from Toyota?
Old 04-22-2009, 12:56 PM   #4
Your link is to the sedan version - I grabbed the liftback one.
The OEM trim pieces are the only thing needed to make it work on an 09.
Old 04-22-2009, 01:06 PM   #5
MGargano
Thanks, that's what I was curious about. I wasn't sure if it was the sedan or liftback version that worked on the 09 so thanks for clearing it up. Any idea where I can find the OEM cruise stalk on the cheap? The dealer wants $115.18.
Old 04-22-2009, 01:16 PM   #6
Actually, I would be that the only difference between the two is the trim, as I believe the fog wiring is identical on both.
For the cruise stalk, check this ebay auction:
http://cgi.ebay.com/ebaymotors/NEW-O...Q5fAccessories
Old 04-22-2009, 02:16 PM   #7
MGargano
I'm retarded... I meant OEM fog light stalk, not cruise control stalk. Any ideas?
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
