Old 04-25-2009, 01:22 AM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I missed this one... Scion transmission fits, but shift cables don't? Did you try using the cables from the Scion? If they don't fit the Yaris shifter... did you try fitting the Scion shifter? Seems like a pretty small problem to deal with to reach a worthy goal.
Old 04-25-2009, 01:27 AM   #2
Morgan
Morgan's Avatar
Drives: 07 MM LB
ok well I tried fitting the transmission, sensors worked and bolted in, transmission mounted to the block but the rear engine stabilizer mount was missing on the scion trans because they have a different subframe... and the scion shifter cables are totally different that the yaris and the shifter assemblies are different...
so if you want the shorter scion gears dont fool around with installing the transmission just swap the gear sets and be done with it, if I had the actual gear puller this may have been a possible modification but I didn't so I cut my losses and returned the scion transmission
but yes I did make a blog post about this a few weeks ago when I tried it.... :)
least I know how the subframe goes in and out of the car know, always good to know - secret hit, its really easy I don't know why people mess with trying to do things from the top its like 6 bolts....
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 03:57 PM
GET FREE PS3/360/Wii check it out! marcus Off-topic / Other Cars / Everything else Discussions 23 09-25-2007 07:51 PM
Test drove Fit, Versa and Yaris... Bought a Yaris! AlexK General Yaris / Vitz Discussion 49 09-10-2007 06:35 PM
The Yaris community magoo_lc1 Off-topic / Other Cars / Everything else Discussions 8 02-14-2007 03:33 PM
