#1 | |
Good to know. Thanks, Scott. I think I'll give it a go.
![]() Drives: 2011 Yaris 5 dr LB Join Date: Apr 2011
CTScott, you're awesome for posting this! I just did it on my 2011. At first, only the on/off was working, but after reading the entire thread, I found that I was also a victim of resistors that were incorrectly marked. I bought the correct ones, and I am in business. Thanks again!
![]() Drives: 2009 Yaris Sedan 5spd Join Date: May 2009
Yay! I've been waiting almost 2 years for this day. Ever since I spotted the thread, I have been itching to put cruise in my Yaris - only waiting for the warranty to run out. My only tweak from the parent post instructions was to use a dual throw momentary toggle switch instead of 2 push button switches.
http://www.flyinglow.ca/flyinglow/20...rol-on-my.html Thanks a bunch guys! |
![]() Drives: 2010 Plain Vanilla Join Date: Jan 2012
I am using Illuminated Pushbutton Switches E-Switch model LP1OA1AB (Digikey EG4641-ND).
Everything works great (thanks guys), but the blue LEDs are too bright. Each switch has a blue LED with a forward voltage drop of 3.4 to 4.0 VDC at 20 mA. I used a 2.2 k resistor to limit the LED current to less than 5 mA. I stole +12 volts and ground from D29 (Instrument Panel Dimmer Control Connector) thusly: ************************************************** ********** +12 VDC from D29 Pin 5 - Brown: Power in from PANEL1 fuse | 2.2 k Resistor (times four – one per LED) | LED (four LED's total) | Ground from D29 Pin 3 - White/Black: Ground ************************************************** ********** I would like the brightness of the LEDs to be controlled by the dimmer pot. Instead of connecting the resistors to Pin 5 (+12 VDC) like I have now, it seems to me I can connect the resistors to either, 1. Pin 2 - Light Green: Output to radio, AC lights, etc 2. Pin 8 - Yellow: Output to Cluster 3. Pin 9 - Orange: Output to Hazard warning signal switch and Door lock switch Which, of any, of these do you think would work best? BTW if anyone expresses an interest, I will gladly post the exact circuit I used, plus a photo of the LP1 illuminated switches in all their blueness. Thanks, Scott |
Nice switch choice!
On the dimmer rheostat connector, the brown wire is +12 and the light green wire is headlight switched rheostat output (which goes from 0V for full illumination to +12 for completely off). You will probably still need to add a larger resistor value to make the switch LEDs be less annoying. With the blue LEDs you often have to go as high as 10K to keep them from being blinding.
Thank you, Scott, for you quick reply.
I will use the light green wire and put a 10 k trim pot upstream of the 2.2 k resistors. It occurs to me that it might be a good idea for ANYone using illuminated switches to have a trim pot upstream of the 2.2 k resistors so they can adjust the LED maxumum brightness as seems best to them. Thanks, again, Scott |
![]() Drives: black 2011 Yaris zen3 Join Date: Feb 2011
hi guys i got a t3 zen 2010
plug d3 pins 123 empty but 4 has light green 5 has brown and 6 has pink how do i do it on my car thanx |
Unfortunately, the ECM on your car does not have the cruise control function built in. Prior to 2012, only US and Canada Yaris had it.
![]() ![]() Drives: 2009 yaris sedan Join Date: Apr 2011
have 2 questions for CtScott the almighty yaris guru:
i have a november 2008 built 2009 yaris sedan (Canadian market) 1. if i use the 2 switch setup, and i turn it on and have to brake will the CC automatically deactivate? 2. how do you tap into the cables on the connector from the on/off switch? 3. is the D3 connector the white connector on the LEFT side of the yellow connector?
#11 | |
Yes the brake overrides CC. If yours has the wiring from the ECM to the steering column, then you can use splice tap connectors (available from most auto parts stores) to connect to the existing wires. Your Canadian sedan may not have the wiring from the ECM to the steering column, and if that is the case you would need to add the ECM pin. This thread has a DIY with more details: http://www.yarisworld.com/forums/showthread.php?t=33750
#12 | |
Correct on both.
great news, i just checked and i have all 3 wires, and my dash cluster has the set and CC indicators.
do i have to use the switches you mentioned, or can i use a plain SPST Normally open pushbutton that i can buy from my local electronics store? |
Ive had my Yaris World cc for maybe two years now. I drove a friends car with stalk cc and HATED it. My four button cc is SO much easier to use!
Question: one button is on/off, another button is set/decel, and button is resume/accel. What is the fourth button?
Cancel.
Drives: 2011 Yaris 4D Sedan Join Date: Sep 2012
Does this work on a 2011 Yaris ?
Hello,
I just bought a 2011 Yaris, and was wondering if this mod is easily possible on that model as well, i.e., is the wiring present from the ECM to under the steering wheel ? Thanks! |
#18 | |
The easiest thing to do is to pop the steering column cover and check for the blue and brown wires on connector D3.
| OEM foglight switch and leather wrap steering wheel | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 8 | 03-11-2009 12:05 AM |
| SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 | justoneyaris | Items for Sale by private party | 3 | 12-04-2008 06:30 PM |
| steering wheel setup | aucorium | Cosmetic Modifications (Exterior/Interior) | 0 | 07-24-2007 01:05 AM |
| How do you take off steering wheel | mrrock | Cosmetic Modifications (Exterior/Interior) | 3 | 12-05-2006 10:16 AM |
