Old 05-04-2009, 09:26 PM   #1
mariann
Drives: yaris 2007
any one knows if the 2007 model come ready to install cruise controll? (its the same model as 2009)
mariann is offline   Reply With Quote
Old 05-04-2009, 10:41 PM   #2
mariann
Drives: yaris 2007
did you read the Can we do this thread
ofcorse. but i go tired on page 4. and skipped to the last pages.
havent found any info about it.
by the way. just now i looked in the 2007 manual - cruise controll. and its exactly as described. also has the plugs as shown. the same wires. and need the same resistors.
i think it will work the same as my dealer said: "its exactly the same vehicle. 2007 2008 2009 no changes what so ever" he was right.
the post is for AT and MT... but here we have only Robotic Transmission... so i think i'll consider robotic transmission as an automatic transmission... hope it will work.
any advice guys?
Old 05-04-2009, 11:05 PM   #3
any advice guys?
Does your 07 have the brown and blue wires in the D3 connector?
Also, does it have the cruise indicator on the combination meter?
If it doesn't have the D3 wires, then it will require the work that nickhjort did on page 16 of the other thread. Once all of the trial and error is sorted out in the other thread we'll put together a DIY for Yaris which need the additional work.
Old 05-05-2009, 10:05 AM   #4
mariann
Drives: yaris 2007
well. this is ehat i have.
thats my D3 connector. i'm sure its the right one because is tried to honk after disconnecting it.
i do have a brown and blue wire but seems they are not in the mentiond above terminals. or is it?
click on the images to see in supersize
and there are somepictures of the display. i couldent find the cruise controll light or set light. maybe you'll find.
i did manage to pull out the A21 connector to see if there is the specific wire inside but got stuck with the L shape plastic wich cover the wires? there is a way to pull it out without breking it?
help please
Old 05-05-2009, 10:40 AM   #5
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
mariann,
It's pretty straight forward. Just cut the ziptie at the top of the cover VERY CARFULLY! Do not cut any of the wires, obviously, or you will be SOL big time. After cutting the ziptie, there are two clips on the left side of the cover. push them in and lift. Then you will see two hooks on the back of the cover, life the cover and pull so that hooks release. And to reinstall the cover just do the opposite. You will have to have a ziptie to replace the one you cut. If you don't have a ziptie, the clips and hooks will hold the cover in place, but the wires undernieth will be hanging loose. Here's some pics...hope they help.
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-05-2009, 04:26 AM   #6
regal
Drives: 09 Yaris 3 Dr White LB
very cool, but is there a tutorial for thos of us who want to you the OEM stock to keep it stock looking? Sounds a much better way to go that the $220 aftermarket option.
regal is offline   Reply With Quote
Old 05-05-2009, 10:00 AM   #7
A couple of people have purchased OEM stalks and will be installing them. Hopefully one will document the process for those interested.
Old 05-05-2009, 06:39 AM   #8
suiller
Drives: Yaris Sol 1.3 dual VVTi 101hp
above all can we do on 2009 model??
Yaris Sol 1.33 dual VVTi model 09 - 5dr
1. full ZX1 additive treatment: oil + cooler + fuel
2. NB treatment: motor oil
3. K&N panel air filter (part num. 33-2211)
4. Fuchs Silkolene Pro SRG 75 gear oil (the best!)
5. UltraRacing 19mm rear sway bar
suiller is offline   Reply With Quote
Old 05-05-2009, 10:02 AM   #9
I don't have the electrical wiring diagrams for the European Yaris to verify that all is the same as for our USDM ones.
Old 05-06-2009, 11:01 AM   #10
nickhjort
nickhjort's Avatar
The on/off button just enables the cruise control. When you push the set button, that's when the ecm know what speed to keep the engine cruising at. Usualy right when i turn my car on I hit the cruise on/off button. Then when I hit the highway and get to the speed I want, I hit the set button and the car remains at that speed. The way CTScott set up the two button system (I have them set up the same way and have tested this), you can also use the set button as the -1mph button...meaning if you're cruise is set at a certain speed and you want it to be just a little bit slower, whenever you hit the set button again it will decrease the speed 1mph. Or you can hold the set button and you will start coasting and when you slow down to your desired speed, you let go of the set button and it will remain at whatever speed you were at when you let go. Hope this explains it well enough mariann.
My Car Rules!
Old 05-06-2009, 12:07 PM   #11
andru47
andru47's Avatar
Drives: 2009 Yaris 3DR LB
Send a message via AIM to andru47
Does anyone have the instructions for the clutch switch for 09 5spd?
Thanks Scott! Now I have a summer project to keep me busy!
My Yaris: The Azure
andru47 is offline   Reply With Quote
Old 05-06-2009, 12:11 PM   #12
Check this out. It's for a Matrix, but the Yaris one is identical in looks and mounting:
http://matrixowners.com/index.php?ac...r&f=23&t=71247
Old 05-06-2009, 12:34 PM   #13
mariann
Drives: yaris 2007
i got the parts. i finish building the prototype (not gonna drill button holes in my dashboard if it will not work. right?
and found that the store gave me N.C buttons insted N.O... i'll drive there tomorow.
any way. i hope the last question. one wire goes to the ECM pin 40 and the other to the ground? or pozitive?
by looking at the schematics its shuld go to the ground. but last chack with you guys if i right.
hope i'll install it tomorow
Old 05-06-2009, 12:41 PM   #14
nickhjort
nickhjort's Avatar
The other wire goes to a ground point, yes.
My Car Rules!
Old 05-13-2009, 04:59 PM   #15
Treyz
~ ambient one ~
Treyz's Avatar
Subscribed
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine
Micro Image
Store - Network - Online
Old 05-13-2009, 10:28 PM   #16
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
I used to have a Pontiac with cruise control and no indicator lights. In my experience, there's no light actually needed - it's quite obvious whether the cruise is on or off simply from how the car behaves. As for the "Set" light, you'll know immediately if the speed isn't set because the car slows down when you take your foot off the gas.
I'm going to install cruise on my '08 with the proper switch and very tidy wiring when I get around to it. The goal is to make a sufficiently tidy installation that even a Toyota tech will think it's factory, and it will take a lot of looking to prove otherwise.
However, I'm not even going to try for indicator lights. It would be nice, but you don't really need them.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 05-15-2009, 06:44 PM   #17
expo2
Drives: 2008 Yaris HB
OK, almost have the cruise install complete. I have the 08 Yaris LB with no cruise light on the dash. I tapped the ECM a-21 connector @ position 40 and ran the wire to the cruise on/off switch on the dash.
Last question: How do I wire the new clutch switch I just installed? Does the wire from the ecm go to the clutch switch first, and then continue to the cruise on/off switch on the dash?
expo2 is offline   Reply With Quote
Old 05-15-2009, 07:17 PM   #18
andru47
andru47's Avatar
Where can I obtain one of those clutch switches? As cheap as possible please :)
My Yaris: The Azure
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
