Old 05-01-2009, 08:46 PM   #12
Liu997
Drives: 2008 Red Yaris LB
I may have had a problem in this step, what does this mean.
Now we must finish modifying the aftermarket harness. Cut the 2 black and 1 solid blue wire as well. The blue/green wire will not be used. Remove the electrical tape holding the end of the harness together. Once everything is pulled apart you should have black, solid blue and solid green wires left in the harness. Use a butt splice to reconnect the 2 black wires. (sorry I forgot to take pictures of the final modified harness):"
I connected the black wire to each other would that be right?
Liu997 is offline   Reply With Quote
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
