Old 05-03-2009, 03:54 PM   #1
Liu997
Drives: 2008 Red Yaris LB
I have no idea from the pics what the second black wire is for. If you look at the switch itself, it has one black wire, which is the ground for the lighting circuit. If you follow the wires from the switch, Blue goes to D3-pin3, Green next to blue goes to D3-pin4, the other green goes to the accessory lighting wire, and black goes to ground.
You mean D4 right? I just checked and there was no D3 pin under the steering wheel
Liu997 is offline   Reply With Quote
Old 05-03-2009, 05:57 PM   #2
Correct - D4 (typo on my part).
Part #s for Fog Light install? Can anyone who works for Toyota confirm? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 73 12-23-2010 05:15 PM
test fit 06-07 Yaris 4 door fog light winson California 15 01-13-2009 08:25 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
