#1 | ||||
Drives: 2007 4 Door Yaris Join Date: Jan 2009
Its pretty much elementary physics. You aren't absorbing as much energy with the tires = more energy gets transferred into the suspension and chassis. To completely write this off is irresponsible. Quote:
And I like getting better gas mileage. That's why I post here. I just like to get the WHOLE story - not the tunnel vision story that hypermilers THRIVE on. |
#2 | |
![]() ![]() ![]() ![]() Drives: Yaris Sedan (auto) Join Date: Jun 2007
People whom you label hypermilers can only attain optimal performance by paying attention to their entire environment, maximizing their safety level while enhancing their mpg. You can say what you want, but until you have experience on both sides of the fence you're simply making statements with nothing to back them up but you're opinion. Fact is, Brian is right and you're wrong. You don't have to accept that, but hopefully your ignorance will not mislead others interested in facts proven by real world experience. For people who want to learn and not buy into conjecture; check out posts by Brian and check out cleanmpg. |
#3 | |
www.tirerack.com If a vehicle's tires are overinflated by 6 psi, they could be damaged more easily when encountering potholes or debris in the road, as well as experience irregular tread wear. But its all a conspiracy huh?? I'll bet you thebarber and supmet work for the big oil companies. |
#4 | |
If you actually did research and tried things out you could find the truth out for yourself. Posting a link from a reseller proves nothing. Believe what you want. I know I believe the over $700 savings in gas costs alone, and improvement in MPG by 15% since I started to slowly test, confirm and then apply the knowledge and techniques appropriate to my driving conditions and car, shared by people such as bailout. I'm also looking forward to seeing how many thousands of km's past mtbf I can go on my tires which show very little wear after 30k of 44-60psi. |
Drives: 2008 Yaris Join Date: Oct 2008
...actually that's not true. A good tailgater drives at least two, maybe three cars beyond their victim. You have to have your empathy dailed up to ten to see where they might brake so that you can brake before they do.
If all you do is look at the bumper of the person ahead of you it's a matter of time before you feel it. Gene |
#6 | |
I have very little experience with tire wear. I'm still on my original tires on my Yaris, and I had two sets on my old Elantra. When I first got the Elantra it had new Potenza G009s on it. I kept them at the pressure Hyundai recommended. After a few months the outer edges wore down quite a bit. My next set of tires were Falken ZE-512s. I played with the pressure until I found a comfortable psi, which was 40 psi. After 63,000 miles the treads had barely worn down at all. I found the ride in the Yaris to be comfortable at about 42 psi on the stock Eagles. 9,000 miles in all is well. I've been consulting this site for tips: http://www.carbibles.com/tire_bible_pg2.html Scroll down about 2/3 of the page. Your results may vary! |
#7 | |
| Best all-season tires for the Yaris? | Rahxephon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 03-17-2013 07:40 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 07:58 PM |
| NEED USED TIRES!!! | natethegreat38 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 12-06-2008 01:11 AM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 02:23 AM |
