#26 |
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
Strange, when I took my Cobra through the Bondurant school of high performance driving they REQUIRED that my tires be inflated to sidewall max. Not negotiable.
I have the stock Goodyears that Toyota puts on the 15" steelies. My three-door hatch is a hopeless, hapless disgusting pig in the corners with 32 psi in the tires. The TRD rear sway bar helped some, but running 51 psi front and 50 psi rear makes it dry corner like it's on rails. That's only six psi higher than sidewall max. These tires are wearing evenly so far as well. I'm not saying that any old tire can accomplish that though. Also, most of the pothole related tire failures I've seen were the result of the sidewall being pinched (crushed) between the road and the wheel. Higher tire pressures should make that harder to accomplish. Last edited by Rick; 05-03-2009 at 07:17 PM. Reason: Brainfart ..... wrong tire brand |
| Best all-season tires for the Yaris? | Rahxephon | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 03-17-2013 07:40 PM |
| tire noob question..what's the widest tire size can run on stock 15"s? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 12-06-2011 10:44 AM |
| Newly installed 15" tires feel 'weird' | kristan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 04-24-2010 07:58 PM |
| NEED USED TIRES!!! | natethegreat38 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 13 | 12-06-2008 01:11 AM |
| Why do all low profile tires have to be of high performance design? | grampi | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 05-16-2007 02:23 AM |
