Old 05-03-2009, 07:15 PM   #1
supmet
Drives: 2007 4 Door Yaris
Originally Posted by voodoo22 View Post
Fact is, Brian is right and you're wrong. You don't have to accept that, but hopefully your ignorance will not mislead others interested in facts proven by real world experience.
WHAT FACTS? No tire manufacturer will recommend double PSI. No car manufacturer will. There are at least 3 people in this thread alone that have seen increased tire wear with increased PSI.
www.tirerack.com
If a vehicle's tires are overinflated by 6 psi, they could be damaged more easily when encountering potholes or debris in the road, as well as experience irregular tread wear.
But its all a conspiracy huh?? I'll bet you thebarber and supmet work for the big oil companies.
supmet is offline
Old 05-04-2009, 08:35 AM   #2
voodoo22
Drives: Yaris Sedan (auto)
www.tirerack.com
No, I don't think the big oil companies would hire you to represent them and I fail to see anywhere where I stated double psi or conspiracy. You don't seem too hung up on being accurate anyways, so your misquotes come as no surprise.
If you actually did research and tried things out you could find the truth out for yourself. Posting a link from a reseller proves nothing. Believe what you want. I know I believe the over $700 savings in gas costs alone, and improvement in MPG by 15% since I started to slowly test, confirm and then apply the knowledge and techniques appropriate to my driving conditions and car, shared by people such as bailout. I'm also looking forward to seeing how many thousands of km's past mtbf I can go on my tires which show very little wear after 30k of 44-60psi.
voodoo22 is offline
Best all-season tires for the Yaris? Rahxephon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 03-17-2013 07:40 PM
tire noob question..what's the widest tire size can run on stock 15"s? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 12-06-2011 10:44 AM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 07:58 PM
NEED USED TIRES!!! natethegreat38 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 12-06-2008 01:11 AM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 02:23 AM
