-YaRiS OwNeR-
Drives: YRS Sedan Join Date: Oct 2008
up up up.... :o
![]() ![]() ![]() ![]() Drives: Yaris '09,GTi '09, BMW 3.30ci Join Date: Oct 2008
bump
Yarisomniac
Drives: 2009 5spd LB Join Date: Nov 2008
Yes it can be done in the 09 - I just changed my speedo gauge backlighting from orange to blue using these from eLed :
http://www.eled.com/product.asp?cata...d=epl3015pbc-a They are slightly bigger than what Vodkalush recommended in his DIY but they worked fine and were easier to work with (slightly). The problem I ran into was the clock on the base 09 LB gets its color from the plastic housing it is in, so changing the LED's would not fix that. What I did was buy some blue 1/8 inch transparent plexiglass and use that to change the clock color. I cut out a window in the orange plastic part around the clock and replaced it with a small piece of blue plexi that I got here: http://www.estreetplastics.com/Trans...Sheet_s/58.htm Cost me like $3 plus the LED's and overall was pretty easy - Use search to find the DIY from others that changed their gauge color lighting |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
plan on doing this in the neer future
"It hurts more when its wet" |
![]() Drives: Sedan Join Date: Feb 2009
ok so i know i can order the bulbs from this website
http://autolumination.com/74.htm but exactly which bulbs is it because there a tri-power and some matrix II so if someone could tell me that would be great I also realize that this thread is really old and im hoping someone will get this still |
Little Eggy
Drives: Toyota Yaris Liftback 3DR 2009 Join Date: Apr 2010
Hey, I bought bulbs from Superbrite but when i try to swap out the bulbs in the stock base, it seems the bulb won't budge out of it's own base. Is there anyway for me to take it out? unfortunately the base i bought is bigger than the stock ones. 5mm. Thank you!!
#7 | |
Little Eggy
![]() Drives: Yaris TS 05 Join Date: Jun 2011
Thread revival! I'm planning doing this on my little car ;) anyone know where I can get the colours condom?
![]() Drives: Toyota Yaris 5 door hatch Join Date: Sep 2012
Ok so I played around with the bulbs on my 08 Yaris, the green in the car is crappy if you ask me... So i installed a High Bright LED, this is just a normal LED that has a 999ohm resister, it involves a bit of soldering(if you want it to be permanent) and ALOT of patience, I will attach the photos, the top switch is obviously the one that i replaced https://www.dropbox.com/s/zoqtlanezy...witches.jpg?m=
If there is anyone out there that would know how to(if possible) change the colour of the radio and its buttons, once again i want them to be WHITE :)
There are no Yaris drivers, only Yaris LOVERS
#10 | |
now that looks neat... Good job CTscott, do you know where i can get hold of these ''tiny surface mount LED's"?
#13 | |
http://www.mouser.com/Search/Product...-VLMW1300-GS08
#14 |
Thanks
#15 |
LOL so i broke the fan switch... If i put 1 on then the air con indicator light works( but no fan) and then 2 3 &4 the air con indicator light switches off and the fan doesnt work... Does anyone have any ideas?
#16 |
I would have to see what you did on the back side of the knob. You may have created a solder bridge when you added your LED.
#17 |
Ah I will double check that particular one, the other two i found a creative way to change the bulb with one that they sell here for park lights, fits into the original fitting, will change that when i get home from work in about 3 hours :(
| Accessory Bulb Types, anyone know? | Ayka | Cosmetic Modifications (Exterior/Interior) | 135 | 04-29-2007 08:33 AM |
