Old 05-22-2011, 12:49 PM   #1
jongscx
Drives: 07 yaris hatchback
Originally Posted by auxmike View Post
If you have power locks from the factory and leave the keys in the ignition, the car won't lock!
I tried it every way and the lock "fights" you and keeps on opening itself!
Cool...
This WON'T work if you leave keys on seat or dashboard, sorry..
... you "Can" if you lock the doors and go out the hatch or the trunk...
You can do this with the car running too...
jongscx is offline   Reply With Quote
Old 08-31-2010, 04:27 AM   #2
Dylan
Drives: Toyota Yaris T3 '07
Thanks for the info WASP. But how do you put the window crank back on with the clip? Is there a certain way of doing it or is it just that easy?
Dylan is offline   Reply With Quote
Old 09-23-2010, 04:44 PM   #3
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
It just snaps back on. Be careful removing it. I lost a clip on the passenger side.
KrazyDawg is offline   Reply With Quote
Old 10-22-2010, 02:25 PM   #4
mistersusan
Fading Fast
mistersusan's Avatar
Drives: 2009 yaris
OK... picture 8 says lift, twist and pop the latch assy. (??????) what holds that mechnism together? AND does it just pop back in?
mistersusan is offline   Reply With Quote
Old 10-22-2010, 02:43 PM   #5
There are two separate things going on in that picture. Once you pull the panel out a bit, you pull out on the door handle, and it pops out of the panel, then you twist it and feed it back through the hole that it popped out of. After that, you finish lifting the panel up to free it from the window slot.
Old 10-25-2010, 08:58 AM   #6
Dylan
Thank you guys you were a great help!!
sorry for the late reply. . . laptop got stolen. . .
Old 01-27-2011, 04:47 AM   #7
milooshea
Drives: Toyota Yaris 1.0L GS 2000
Yaris 1.0L GS 2000 Driver's Door Panel Removal
I need to replace a driver's door mirror that a speeding, inexperienced driver smashed when passing in a country lane. Bolts visible but inaccessible without removing the interior door panel.
The information and photos about the newer models are helpful and encouraging, but unfortunately don't match up fully with my Y2000 model. I've removed 2 screws, but everything is still rock solid. Window control unit comes out easily, but no screws underneath it. Do I need to remove the door catch unit or are there screws concealed somewhere else?
Grateful for any advice and help anyone can offer.
Thanks in advance,
Milo
milooshea is offline   Reply With Quote
Old 01-27-2011, 11:57 AM   #8
Thanks in advance,
Milo
There are 3 on the 1st gen mirrors:
Old 02-09-2011, 03:26 AM   #9
rye7jen
rye7jen's Avatar
Drives: 2nz-fe '10
Is there a video (tried Youtube but no luck :sad:) where you can get that window crank off? I've tried it myself many times but my rag just torn into pieces and it was a PITA inserting the rag at first. Just want to see a decent video how they do this in a perfect way.
rye7jen is offline   Reply With Quote
Old 02-09-2011, 06:30 AM   #10
1stToyota
1stToyota's Avatar
Just a quick note on removal of the plastic liner: use a safety razor blade or sharp knife to cut through the adhesive...no mess or stretching of the plastic, and liner will stick right back in place like it was never removed.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 04-28-2011, 06:20 PM   #11
sosopo
sosopo's Avatar
Drives: 2008 Toyota Yaris LB
thanks W.A.S.P I chnged my speakers today and this really helped me a lot
sosopo is offline   Reply With Quote
Old 08-15-2011, 04:55 PM   #12
Kramyelraf
Drives: Toyota yaris lift back
My driver side window was starting to get harder to roll up and down. This helped out a lot. When I wanted to give it a look. Thanks
Kramyelraf is offline   Reply With Quote
Old 01-07-2012, 10:18 AM   #13
donkeyned
Drives: 2010 Yaris 1.4D
Thanks, very clear. What does the cover removed in photo 2 do, and how do you put it back? Mine has a small white square plastic post underneath it.
donkeyned is offline   Reply With Quote
Old 01-13-2012, 09:07 AM   #14
The Boy Riley
Drives: 2009 Yaris
The white post is a pain in the arse, I've put a new wing mirror on today and had some issues with it.
The cover has a horse shoe shaped recess in the end, when you prize the cover out, the clip may or may not be supposed to come with it, either way do not try to get the white one out on its own, you end up snapping the top part off and then the cover will not sit back in without a little imagination. normally however the white clip goes into the cover then you pop the cover back on to put it back.
Just carry on as this guide shows, when you start to pull the main panel off the clip just pops out with the rest of them.
And thank you to W.A.S.P. this guide was incredibly helpful :)
The Boy Riley is offline   Reply With Quote
Old 01-22-2012, 06:54 AM   #15
birdman
Drives: '08 Blazing Blue Yaris LB
Twingo's are cool.
birdman is offline   Reply With Quote
Old 11-09-2012, 11:46 AM   #16
enyajtrebor
Drives: Yaris 1.3 T Spirit
Excellent pics - how about the rear offside door panel. I need to take it off as the door won't unlock via the remote or inside locking button
enyajtrebor is offline   Reply With Quote
Old 11-09-2012, 01:42 PM   #17
The rear is almost identical to the front. There is one screw on the inside door handle, and one on the arm rest door pull (you will see a small (1cm x 1cm) square cover that you pop off to get at the screw). After removing those two, get your fingers under the edge of the door panel and pop the trim clips. all around.
Old 11-09-2012, 01:47 PM   #18
enyajtrebor
Thanks for that - a job for tomorrow morning
-- Liftback Rear Speaker Removal? -- rarmogan In Car Entertainment + Electronics (audio / video / alarm) 2 09-25-2006 03:48 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
American colors for the LIftback? debbiezan General Yaris / Vitz Discussion 4 02-25-2006 01:38 AM
