Old 05-16-2009, 05:35 PM   #1
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
Pics for now... I will take more in an hour or so when I get it put in...it's raining like a mofo here now...
This is my switch I bought at radio shack. You get four in a pack for 3.59 I think.
Aluminum bracket, switch and bolt that replaces stock clutch switch.
My Frankenstein (It's ALIIIIIIVE!!!!...almost)
Just make sure you have a SPST switch that is normally open...not closed. Also make sure it is long enough to touch the little black plate you see in the picture. I think mine is barely gunna work. If not I will probably epoxy something onto the end to make the button part longer. We'll see in a few.
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-16-2009, 06:09 PM   #2
nickhjort
nickhjort's Avatar
Well the switch was just barely too small. So JB Weld time...
I used a cap from a can of liguid wrench :) Now it truly is a frankenstein haha. But it's all good. Nobody can even see it unless they stick their head under the dash. Anyway more pics to come soon when it's installed in the car.
My Car Rules!
Old 05-16-2009, 08:52 PM   #3
nickhjort
nickhjort's Avatar
Alright peeps, it's in. It works so far when hooked up to the meter. Tomorrow I'm gunna wire it in and test her out. Now all I'm waiting for is the led "module", courtesy of CTScott then I'll be all set
My Car Rules!
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 10:12 PM
