Old 05-17-2009, 04:54 PM   #1
cdydjded
Drives: Yaris LB Turbo
AEM FIC works in Yaris......Sort of
Well I decided to give it one more try. This time what I did is I conected to 1 input at a time. Here is what works without problems:
TPS Sensor
Injectors
Cam Sensor
Crank Sensor
Problem inputs are:
MAF
O2 Sensor
Right now I have the MAF disconected. With it connected I have a hard starting problem & the car run like shit. The O2 is connect & the car starts, runs & drives fine. The check engine light is on. I checked the code & I am getting the following:
P2239 O2 Bank 1 Sensor 1 Positive Current Circuit High
P2252 o2 Bank 1 Sensor 1 Negative Current Cuicuit Low
Im assuming that if I disconect the O2 the check engine will go off. Im going to try that later today. I do not have a wideband mounted so I cant tune on the fly. I keep everyone posted on the progress.
cdydjded is offline   Reply With Quote
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 02:03 PM
is the yaris for me? sauruman New YARIS Purchase Forum 14 02-27-2006 08:27 PM
