Old 05-16-2009, 03:31 PM   #19
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
thanks for the input everyone. i will consider adding this in the near future as my experience gets better. for now however i think that learning my cars characteristics without the throttle controller first, will make adding it in the future much more benificial as i will know my cars limits and weaknesses fully by that point. for now im going to focus on picking up some decent tires (star specs), and possibly those nifty little adjustable camber bolts Garm is selling...
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 05-16-2009, 03:59 PM   #20
drifto
drifto's Avatar
Originally Posted by kurokoma-kun View Post
ah ok, I was trying to think of things you didn't have yet, you need to update your garage!
damn i totally forgot about my garage! lol
its updated now thanks
07 Yaris LB 5spd
Old 05-16-2009, 04:05 PM   #21
Klink10
Klink10's Avatar
Thanks Garm...that is a decent price for this plug and play unit.
Old 05-16-2009, 11:18 PM   #22
Tamago
Tamago's Avatar
Drives: UZJ100
Originally Posted by Russelt3hPirate View Post
this has easy to use buttons.
any thoughts?
It did less for me than the throttle controller would. LOL
should have had easy-to-use-buttons on the FIC?
Old 05-17-2009, 01:30 AM   #23
That would be nice -- LOL, good one.
Old 05-18-2009, 03:02 PM   #24
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
FYI -if you are AutoX-ing under SCCA classing, this would put you into either a Prepared or Modified category, much like adding forced induction or CF body panels. the perfromance gain is not worth the class jump, as you'll be up against vehicles with drastically greater levels of preparedeness (IE: swapped motors, turbos, etc). The same is true for the NST and other underdrive pulleys. If you are an honest autocrosser who wants to race/win on skill and not cheating, then you have to disclose these mods, or ask the other in your desired class to grant you an exception to run with them. Generally, they will do so if its not performance-enhancing (non-standard rims, add-on spoiler, etc.), but will probably ask you to register in your proper class if you've done any of the mods listed above.
There are many clubs out there that use a much less-stringent classing system, and they are perfect for cars that have been modded for street performance (BMWSCCA, PCA, NASA), and you can register in exhibition classes to compete without winnign trophies or points.
If you really want to compete seriously and earn points, plan your mods around the class in which you think you'll be competitive (H-stock or ST are probably the only 2 classes the Yaris has much chance in untill you go full-bore and swap-in a 2.4L or a massive turbo kit and go full Modified class.)
There is a Street Touring (ST) class that is intended to allow many of the most common handling mods found on "tuner" cars, but it still will not allow a change to the engine management system (throttle controller). Not sure about the pulley swap. SCCA.com has a full classign checklist on its site if you want to see where you'd end-up.
Remember: either be honest and ask for a "waiver" fromt he competition, ragister in your correct class, or don't show up. Its all about being the best driver!
Old 05-18-2009, 03:14 PM   #25
drifto
drifto's Avatar
i agree, and im an SCCA member.
07 Yaris LB 5spd
Old 05-18-2009, 03:16 PM   #26
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
the Yaris can hang in FSP with the right setup and the right driver. :D
Russelt3hPirate is offline   Reply With Quote
Old 05-18-2009, 09:14 PM   #27
drifto
drifto's Avatar
im planning on attending every auto-x event i can this season. my main reason is to have fun, but at the same time i take it very seriously, i want to learn and advance my driving technique and capabilities.
basically, ive always wanted to do this, and ive always made excuses in the past to put it off.
but life as they say is too short, so im starting to change my way of thinking about certain things.
to do this involves a lot of sacrifice, as with work and expenses, spare time etc. but its worth it. for me it is not just a hobby, more rather of a way of living. i find myself thinking as im driving... about throttle control, braking technique, looking for new lines on the roads i take to and from work. trying to apply what ive learned from the track to everyday driving. and to be honest out of all the dumb teenage days of street racing and thinking i know how to drive, i realized i didn't know much at all about how to truly drive my car. i learned quite a few things after only one day of auto-x, but most importantly that ive got alot to learn. and im looking forward to it.
just wanted to share these thoughts, crazy as they may be...and hopefully this weekend some more of you ny/nj peeps will show up to our little microimage auto-x meet this saturday than did a few weeks ago.
lol
07 Yaris LB 5spd
Old 05-18-2009, 09:43 PM   #28
Tamago
Tamago's Avatar
Drives: UZJ100
i have this sneaking feeling a good set of R comps will make 20X more difference and cost about the same as you're going to pay for a plastic box with buttons..
Old 05-19-2009, 12:21 AM   #29
kurokoma-kun
Drives: 2007 Yaris HB
Drifto, looked in your garage again, good job! Did not see a rear sway bar though... if you are wanting to to get better you really need to be able to push it in the corners, and the sway bar will help you ton!
You know how in the slalom it feels like your car is rolling around like a boat on the water? The rear sway stiffens up the suspension so you can get through parts of the course involving shifts in direction like that faster.
Also, you know how bad the Yaris understeers--you turn the steering wheel but the car keeps going straight? The rear sway helps with too.
As a beginner you might tear the crap out of a set of pricey R comps just by overdriving the course. Lots of people prefer to learn with something cheap, especially if you have the habit of scrubbing off speed with your tires.
Old 05-19-2009, 01:01 AM   #30
drifto
drifto's Avatar
yeah, the rear sway bar is a must... i was looking into the dunlop star specs as well. a few people here have recomended them. as far a r-comp, im gonna stick with street tires until im a little more proficient at the track. plus i dont wanna jump to another class due to tires yet.
... and yes i do have a little concern with the slalom, my car feels unsure of itself, kinda sloppy like you said. during the sweeping turns or hairpins it feels good, i just need to develop my lines better.
07 Yaris LB 5spd
Old 05-19-2009, 01:55 AM   #31
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Autocross with my Yaris has been a lot of fun. Suspension is all TRD with sway bar. YARSTAR sold me his spring stiffeners which made a noticable difference! Thanks again!!! They may have nullified the need for a bigger sway bar...for now. I bought some camber bolts from Garm and will try those out next.
I am in ST class which allows some mods including underdrive pulley, but still street tires. I'm using my Kumo MXs to their max. I found that I have to keep the front pressure pretty high.
You guys are right about using expensive tires when learning, can't wait till I know when I've learned enough to get better tires though!
I'll have a load of fun getting there for sure.
Lazerdot is offline   Reply With Quote
Old 05-19-2009, 02:26 AM   #32
^ NICE!
Old 05-19-2009, 07:01 AM   #33
AlainMikli
AlainMikli's Avatar
It's listed on my website, and I have one in stock. If you want to start a Group Buy and get five people to commit, I can get you a better price. Currently, MSRP $430. My price: $329 shipped.
Awesome price, a way cheaper than all ebay seller
To do: Supercharger…
Old 05-19-2009, 11:59 AM   #34
drifto
drifto's Avatar
kurokoma-kun i looked at your garage, and i see you have a domo-kun power-up mod like me. very nice
also, very nice ride i like the engine cover nuts...
07 Yaris LB 5spd
Old 05-19-2009, 12:15 PM   #35
Tamago
Tamago's Avatar
Drives: UZJ100
you have a VERY lax crew if they'll let you run a carbon fiber hood in STS :)
Old 05-20-2009, 02:21 PM   #36
kurokoma-kun
Originally Posted by drifto View Post
...i see you have a domo-kun power-up mod like me.
Domo-kun for President!
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 05:36 AM
