Hack.... What hack ??
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Get your nephew some extra brownie points for creativity and run it off solar power.
#4 | |
Drives: 2008 Yaris Join Date: Oct 2008
Keeping that current around ten mA would run the LEDs cooler... I'd recommend a 560ohm resistor, which would give you a more gentle 11mA to 12.5mA range, assuming a 3 to 2 volt drop across the LED. I used to use 470ohm resistors with 5 volt sources and LEDs... I like to keep things on the low to middlin end to preserve function and reduce heat on working parts. Gene PS If someone can scan in the LED's spec sheet we can do a better job of calculating a good current limiting resistor for this project. |
| What is needed for coilovers | justinparadise21 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 01-03-2009 01:53 AM |
| Who Bought the Basic Model and How Much? | yarisugi | New YARIS Purchase Forum | 36 | 12-30-2008 01:17 PM |
| Tein Basic Damper Coliey's Vs. Tein S. Tech Springs | ToTo | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 35 | 05-07-2007 06:08 PM |
| TEIN - Basic Coilovers *Now Available* | EnduroMTS | Sponsors Classifieds Area | 4 | 10-13-2006 03:43 PM |
| TEIN Basic coilovers | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 06-26-2006 02:57 AM |
