Old 06-10-2009, 02:01 PM   #1
SaerinRhoe
'09 Yaris
Drives: '09 Yaris
Congrats! I'm still floating around 42.4 - 42.6 mpg per tank so I'm hoping that higher numbers will come as the weather warms up some more.
S.R.
2009 Yaris 3-Door Liftback MT Black Sand Pearl
SaerinRhoe is offline   Reply With Quote
Old 06-10-2009, 06:51 PM   #2
S.R.
Damn good job. What hypermiling tricks do you do?
Old 06-10-2009, 09:49 PM   #3
Kal-El
Kal-El's Avatar
Yeah, even with AC these easily do 40+ mpg. That's why I question those who will sweat in their cars to save gas.
Hey Kaotic, an off topic question since you mentioned car-pooling: With your 17's and lowered suspension, does your car maintain enough wheel clearence with 4 people in it? What is the estimated weight of the four people?
Sometimes I and 3 other large adults (I'm 260 lbs and the others average about 220) pile in and it sinks my stock suspension on stock wheels pretty low. That type of load really taxes the Yaris but it handles it (although it is well over the factory recommended weight capacity).
I ask because I will soon be getting rims and lowering springs and don't want to run into issues (although most of the time it's only 1 or 2 riding in it)..
Thanks man.
Old 06-10-2009, 10:59 PM   #4
Thanks man.
It really depends on how low you will go and the offset of your rims. My rims are 17x7" with an offset of +40. The S.Tech's lower it about 2 inches for the sedan. I weigh about 135lbs, and one of my friends weigh 160 or 180 (I forget). My other two friends weigh about 110 each. We have backpacks and laptops, but those don't weigh too much. With all of that, I still don't rub (other than the usual freeway dip rubs). I've also had camping gear with two other people who weigh about 110 each. Just the usual rubbing again. When my dad was still alive, I had his wheel chair and some bags in the trunk, and a total weight of about ~580 lbs of passenger weight, and no rubbing (was on the stock 15" steelies at this time).
Old 06-10-2009, 11:10 PM   #5
Kal-El
Kal-El's Avatar
Thanks! Geez, your HALF my weight. And I'm just 6'1" with a 37" waist but I was into bodybuilding for a while. My crew of four equal over 900lbs in the Yaris.
I would definitely not go more than a 2" drop. I'm still debating whether to go 16 or 17". The pro's and con's seem to equal out and it's driving me nuts trying to decide.
But anyway, sorry to take your thread on a tangent.
Old 06-11-2009, 09:24 PM   #6
Thanks! Geez, your HALF my weight. And I'm just 6'1" with a 37" waist but I was into bodybuilding for. My crew of four equal over 900lbs in the Yaris.
hahaha, I'm working on gaining weight. hahahah.
I'd probably go with 16's in your case. It'll give a bit more tire wall for more shock absorbing.
And don't worry about straying off to a tangent, I really don't mind if my threads go off topic. hahaha.
Avoiding the A/C natethegreat38 Fuel Economy Forum 52 11-01-2022 05:24 PM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 10:17 PM
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 05:31 PM
Easy Defrost A/c running fix billk General Yaris / Vitz Discussion 14 01-16-2009 09:53 PM
