Old 06-12-2009, 12:41 PM   #1
detroiter
detroiter's Avatar
I don't have a scanguage or anything but the mpg difference between going 60mph and 70mph seems pretty big. can anyone supply some information in the mpg gain between doing 60 instead of 70?
Old 06-12-2009, 09:05 PM   #2
voodoo22
Drives: Yaris Sedan (auto)
about 5+ mpg less. For great fe you have to go 55 and under with no a/c.
voodoo22 is offline   Reply With Quote
Old 06-15-2009, 05:11 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
there are tons of factors when going that speed. Drifting behind a semi I can get very high numbers, even when doing 70.
You can expect to see around 5-10MPG difference on average between the two speeds... especially if you don't try the "Hangtime" skill... Tho hangtime I think has been exaggerated, it does help. I don't think it really has anything to do with ECU maps or whatever, but rather physics of energy & torque required to speed up versus energy/torque required to maintain speed.
There are some times I notice that going slower makes it harder to get good mpg's than slightly faster... for example... I find it easier to get good numbers going around 60mph than 55mph on the highway I use to go home. Regardless of of fast I go I seem to use the same throttle possition after I get up to speed and back off on the trottle a bit. So really, the slower speed, but same usage of gas means I get lower mpg at 55. That doesn't appear to be true on all roads/highways tho.
Still haven't gotten to 45 yet. I lowered my tires back down to 40psi... so I don't know if i'll see it ever. 43's seem to be what I see. I had one 250+ mile trip that I got almost 48mpg on, But not for a full tank.
Old 06-17-2009, 08:07 AM   #4
voodoo22
Please don't draft; aka tailgate; it's one of the most dangerous things you can do on the road.
Old 06-17-2009, 10:39 AM   #5
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
That's drafting.
Old 06-17-2009, 02:36 PM   #6
voodoo22
That's drafting.
Thanks!
Old 07-02-2009, 04:13 PM   #7
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
did I mention how close I was? As myth busters showed, you don't have to tailgate to get gains... When doing 70mph... even 50-100ft behind will give noticeable improvements in efficiency.
Old 09-17-2009, 10:24 AM   #8
Zaphod
Drives: Big Yellow
I just got 54.5 on a trip from St. Louis to Indianapolis and back with some city driving in between. That's no scanguage/ecometer, and the car still hasn't even had it's first oil change (although I'm doing that today just to get it out of the way before winter kicks in).
I usually get 43.6 average between my tanks, but the biggest factors for me was the city to highway ratio, and the fact that the engine was warmed up well as normal daily trips are just not long enough to warm up fully.
Of course, I hypermilled big time to prove a friendly point to a Prius owner, allowing for 45-60 on hills and generally cruising at a mere 50 on relatively flat stretches. I was able to achieve all of that staying within the speed minimum/maximum ranges fairly easily. I don't think I could have gotten above 50 by just remaining at 60 the whole way, especially on the hills.
I've yet to hear from someone tailgating a semis (which is dangerous anyway) achieve those same numbers, and doubt I ever will as they're still running their engine at higher RPMs.
Zaphod is offline   Reply With Quote
Old 09-28-2009, 10:24 PM   #9
2+2
Drives: 09 3Dr Manual
Just to let you know, I drive a semi and when I see someone trying to catch a draft back there I usually slow down until they give up and go around. I'm not even sure why I do that. I mean if anything goes south while they're back there and they end up underneath my trailer it's their fault not mine. But then I guess my to-do is full enough and I just hate the thought of adding keeping them healthy to the list. That probably sounds cold and I guess it is.
Congrats on the 45 mpg!
2+2 is offline   Reply With Quote
Old 06-15-2009, 10:13 PM   #10
Hypermiler
Beware of hybrid hype!
Hypermiler's Avatar
Drives: 2009 Toyota Yaris 5 door
This is a good read, rather long, but very good. Basically states that all vehicles begin to see a decrease in efficiency at speeds above 65mph due to wind resistance, etc.
http://en.wikipedia.org/wiki/Fuel_ec...conomy_studies
Hypermiler is offline   Reply With Quote
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 07:31 PM
Why is my new 09 Yaris MPG is so low soup1207 Fuel Economy Forum 34 06-12-2009 04:45 PM
52.60 mpg Kaotic Lazagna Fuel Economy Forum 42 05-19-2009 02:45 PM
Help me see 55 mpg! Loren Fuel Economy Forum 76 04-02-2009 05:23 PM
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 06:48 PM
