I think adding some toe out on the rear may help but I don't want to prematurely wear the tires.
don't add toe out. as previously discussed, this is a mod to be done for those of us who race almost more than we street-drive. not a good thing to do.
What?
Drives: 2007 Yaris LB Join Date: Nov 2008
Geez, somebody move this thread to "cosmetic mods" already.
Apexing Egg!!
LOL
at least they admit they want big brakes for the look
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
PHX, some camber in the rear should help alot.
as Tamago said I wouldn't do toe out specifically, and I seriously wouldn't suggest more than -2.0 rear camber. |
The camber bolts are for the front only, to answer the question. Rear camber uses shims (or washers with the Penguin Garage rear hub spacers).
![]() ![]() Drives: white stock yris Join Date: May 2009
If you put a washer under each lower bolt wont this also adjust the toe to a little out because the front bolt is higher then the rear?
Would you need more negative camber for track with stock springs and a rear sway bar then stiffer springs all around because the body rolls more? How much camber is too much? |
#8 | |||
I'm on stock steel 14 inch wheels. Tires are 185/60-14 Bridgstone potenza 960 pole position (all season). I also added a 23mmultra racing sway bar. I figure since the tires feel as if they are rolling before they emit a screaching sound that the tread is not in full contact with the road. Pressure is 38 all around and there is still body roll in the corner (stock springs). I don't want a stiffer ride or to spend more then is necessary to get te car handling great at its limits. Im willing to make allignment adjustments for track and street.
#10 | |
2.2 up frontand 2.4 in the rear. The washers are a little thick. I have 1.5mm washersto replace the thicker ones. Your right abouut the back having too much camber. The outside of the tires only see asphalt during hard corners . I have not measured rear toe but with the thick washers the car rotates nicely without feeling unstable. Front toe is close to 0.
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
I know the design of the rear torsion beam of the Yaris is a bit different to my Echo in that it has some passive toe change geometry or something built in to it, but has anyone checked what happens to the rear toe when the wheels travels through their stroke?
negative camber turns into toe-in apon compression.
#14 |
That's a bummer, nice and safe from Toyota's point of view I guess.
#15 |
We've been hinting at this for a few weeks now.
We've got the Camber Shims ready for shipping. http://www.yarisworld.com/forums/showthread.php?t=19450 |
#16 |
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
What does this do to the cars handling?
#17 |
did you not install your set yet?
#18 |
toyota
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| Ultra Racing 23mm Rear Stabilizer Bar | Loren | Performance Modifications | 62 | 05-18-2009 07:20 PM |
