Old 06-24-2009, 02:56 PM   #1
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
Voltage reading from SG
Can anyone with a SG go out and tell me what voltage numbers they are seeing on it? My car won't hit 14v while running no matter what I'm doing or what accessories are on...it usually hovers around 13.7-13.8v which I know is not bad, but seems weird. The lowest it hits is 12.9v with my audio system at full tilt, AC on full blast and all the lights on. I am not experiencing any voltage related problems with the car, just curious as to why this is.
The Spectacle is offline   Reply With Quote
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 02:15 AM
Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder bieniman DIY / Maintenance / Service 4 05-20-2009 12:40 AM
possible alternator (voltage regulator) issue jesse1000 Canada 3 03-09-2009 10:10 PM
High voltage -m- DIY / Maintenance / Service 7 08-01-2007 10:48 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 02:01 PM
