Old 07-06-2009, 09:05 PM   #1
Originally Posted by Pikachu View Post
This is how I interpret the way the modified install kit works. Please tell me if I got it right:
1) I install the Toyota factory Fog Light relay in the D46 slot on the top right of the Relay block, and a 15 amp fuse in position 12.
2) I disassemble the wiring harness and wire one side of the switch to D4 pin 3 (Yellow wire into the Headlight switch connector)
3) I wire the other side of the switch to D4 pin 4 (Orange wire). This takes the place of the fancy headlight switch and grounds the coil side of the relay through the dimmer switch.
4) I wire the illumination from the switch to the green wire in the console (Instrument lights).
5) I attach the hot wire from the fog lights to either pin 1 or 2 of B13 in the engine room fuse box.
6) I connect the ground wires from the switch harness and the Foglight harness to ground.
6) Did I miss anything?
That's correct and all of it.
I installed a set on my 09 as above, except I didn't like the included switch or the console location for it, so I installed an LED lighted rocker switch next to the dimmer rheostat. I grabbed the illumination feed right off of the rheostat output (Brown wire in Pin 5 is +, Green wire in pin 2 is -).
Old 07-06-2009, 10:40 PM   #2
Pikachu
Drives: 2009 Yellow Jolt Yaris 3 door
Thanks for the feedback. I ordered a relay and 09 bezels. (I hand carved the old ones but am not happy with the results. It isn't easy to carve a good elipse.) I will let you know how it comes out.
Pikachu is offline   Reply With Quote
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 01:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 06:46 PM
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
Before I start calling around: fog light install prices St_G Cosmetic Modifications (Exterior/Interior) 4 03-17-2007 09:45 AM
Finally installed oem ebay fog light for hatchback Adriaan General Yaris / Vitz Discussion 6 12-27-2006 04:24 PM
