Old 07-07-2009, 10:48 PM   #1
Your part list is correct. You don't need the 99-8216, just the 95-8202. You reuse the OEM radio's mounting brackets to mount the new HU.
Old 07-23-2009, 03:34 PM   #2
Reeves360
Drives: 09 Yaris Sedan, 91 ToyotaTruck
Send a message via AIM to Reeves360 Send a message via MSN to Reeves360 Send a message via Yahoo to Reeves360
OK, so I need:
Silver Toyota Dash Trim p/n 55405-52640
Metra Gap Filler 95-8202
I thought that I would need a Toyota to Pioneer wiring adapter so that I don't have to splice up the Toyota plug into the Pioneer. Any ideas on what that part number might be and if I need it? Are there any other parts that you guys can think of that I'll need?
Thanks for the help.
Reeves360 is offline   Reply With Quote
Old 07-23-2009, 03:49 PM   #3
Derek3CE
Vitz!
Derek3CE's Avatar
Drives: 2005 Echo 3dr HB
I used the same Metra kit to install my double-din radio. I also went to crappy tire (Canadian Tire, pep-boys or something similar in the US will probably carry them) and got the Toyota wiring harness kit and soldered it together with the Pioneer one.
Pic of the stereo installed (this is an '05 Echo hatch):
2005 Toyota Echo CE Hatch
-- GTSpec strut tower brace & front chassis under brace, Tanabe rear under brace, Progress 22mm rear anti-sway bar, Energy Suspension front poly anti-sway bar bushings, 16x7 MB Boost wheels, 205/40R16 Toyo Proxes 4, JDM power mirrors, Tein SuperStreet coilovers w/pillowball mounts, TRD Quickshifter (using stock weighted shift knob) --
Derek3CE is offline   Reply With Quote
Old 07-23-2009, 04:04 PM   #4
Reeves360
Yaris to Pioneer Wiring Kit
Any chance you know what the part number is for that wiring kit?
Old 07-23-2009, 04:09 PM   #5
Reeves360
I'd also like to do this.
AVH-P4100DVD Bypass
I think I'll also need a Auto Zone #19273 Duralast Relay or a similar relay in order to bypass the safety features for full iPod control while I'm driving.
Old 07-23-2009, 04:16 PM   #6
AVH-P4100DVD Bypass
I started watching the video and was thinking why the heck isn't he just grounding the ebrake wire. Then, at the very end he mentions the need for that HU to see the ebrake input toggle, instead of just being permanently grounded.
Tags
double-din, p4100dvd, pioneer, stereo, touch screen
