Old 08-04-2009, 08:58 AM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Eagle LS came with 08 and 09's.
05-07 had bridgestone RE92.
btw, when the tire states max PSI, it means max PSI when warm.
henryG.: If you wanted 55 profile tires, you should go with 205/55R15 instead of 195/55R15. I drive 195/60R15 in the winter and 195/55R15 in the summer. I wish i had 205's instead.
Old 08-04-2009, 10:14 AM   #2
BailOut
Steals terrorist's lunch
BailOut's Avatar
That is incorrect. All tire pressure metrics are rated and measured when the tire is cold (<= 70F) for consistency. This is why it is always recommended that you check and adjust tire pressure first thing in the morning.
Heat expansion is calculated into the "cold" numbers.
- Brian
Share the Road
Old 08-05-2009, 08:39 AM   #3
IllusionX
are you sure? i freaked out when i saw 55psi on my bridgestone Re92 after a long day driving on a hot summer day..
Old 08-04-2009, 04:45 PM   #4
Nope, my '07 came with the Eagle LS's.
Anyone from Missouri? MPG problems inside 4MPG Fuel Economy Forum 31 12-17-2008 05:48 PM
Premium Gas Kaotic Lazagna DIY / Maintenance / Service 215 08-15-2007 03:24 PM
