Old 08-12-2009, 02:57 PM   #1
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
scare as hens teeth from what i've seen- many yards THINK they have it until they double check
odd thing is there are scads of the ones with just speedos
lots of youngsters totalling their cars from the photos the yards run
.....and it'll be a cold day in hell when i'll pay 420 for a new cluster
to be precise it'd be a cold evening(s) in the guest room if my wife discovered i paid 420 for the cluster!
Lewis is offline   Reply With Quote
Old 08-12-2009, 05:31 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
man you guys are getting ripped off! But then again im so used to ordering stuff through my company and our account with our local dealer really helps a lot. either way they told me they could reprogram the mileage for a programming fee and thats all. i just dont have the spare cash for a programming fee just yet. but ive clocked 2500 miles on this new cluster with no issues.
mikenacarato is offline   Reply With Quote
Old 08-26-2009, 11:30 PM   #3
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
I wonder why programming can't be accomplished in Techstream?
Old 08-26-2009, 11:39 PM   #4
Goku87, so far I don't have any solid info. I am looking into purchasing a Chinese clone of the techstream VIM for $1500. I believe, based on Mike's dealer's response, that it can be done using techstream.
Old 08-27-2009, 12:00 AM   #5
goku87
goku87's Avatar
Drives: Black HB
jebus that is a lot of $$$
goku87 is offline   Reply With Quote
Old 08-27-2009, 09:45 PM   #6
It is indeed, but it is a whole lot less than $7,500 for the real Toyota one. My interest in it is to "sniff" its communication when doing various things to the ECM or other ECU's. This would allow me to build inexpensive modules to allow others to do those same tasks. It also has the ability to flash the ECM. Sniffing that process is the key to cracking the ECM.
Old 08-27-2009, 11:20 PM   #7
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
does anyone have a 08 yaris lb automatic trans ecu with 35000 miles or less on the car when it was pulled im looking for one to buy ?
pennyracer is offline   Reply With Quote
Old 08-29-2009, 06:33 AM   #8
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
It's also possible they didn't install it correctly, or one of the 50 or so pins were bent, etc. that's a pretty fragile piece. I think that idea makes a lot of sense though.
Old 11-23-2009, 11:32 PM   #9
DamianShadowPaw
Drives: 2008 Yaris 4 door
I just want a clear answer... will a cluster with a Tach work in a Yaris that did not come with a Tach >.> millage doesn't really concern me.
DamianShadowPaw is offline   Reply With Quote
Old 11-23-2009, 11:45 PM   #10
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
yes it will, at a meet last week, we had a 09 S automatic cluster swapped into a pre 09 no tach (manual), worked, we dont know about ODO tho.
Check out my Build thread:
Old 11-30-2009, 03:15 AM   #11
goku87
goku87's Avatar
Drives: Black HB
looking back on this i guess i'm glad i never got the new cluster lol.
Old 08-18-2010, 01:52 PM   #12
83800-52F30 is Canada/Mexico 06-07 for non-ABS, so it will work on yours and will be in KM.
Old 08-19-2010, 03:55 AM   #13
ricepower
ricepower's Avatar
Drives: Yaris Y Sedan
Send a message via MSN to ricepower Send a message via Yahoo to ricepower
Thumbs up
I think it has the ABS..this is the description i got from toyodiy.com
83800-52F30
NCP93..MTM..CND; WITH 15 INCH DISC WHEEL & CRUISE CONTROL & ABS(ANTI-LOCK BRK SYSTM)-WITH(WITHOUT BRAKE ASSIST)
ricepower is offline   Reply With Quote
Old 08-24-2010, 08:47 AM   #14
ricepower
ricepower's Avatar
Thumbs up
My new sedan instrument cluster 83800-52F30
My old instrument cluster 83800-52F80
Many thanks to ebay seller LKQ
Old 08-24-2010, 08:53 PM   #15
CB900F2
Drives: 08 Sedan
du2efs... If you use a flash light on the cluster, can you see the outline of the "Cruise" control logo on the cluster??.. It should be near the top right side of the speedo..
Old 08-25-2010, 10:32 AM   #16
ricepower
ricepower's Avatar
the cluster p/n 83800-52F30 I got has no cruise control led or indicator. I have checked the PCB, no resistor and smt led. :(
Old 11-27-2010, 01:39 PM   #17
darkMINI
Drives: 08 hatch
Before you swapped the ECU was it just the Tach dial and pointer not illuminating, or both the Speedo and Tach dials/pointers?
'08 3dr HB, Black Sand, AEM, 16x6.6 Mini-Cooper wheels, DynoMax, Cruise, de-TPMS'ed.
darkMINI is offline   Reply With Quote
Old 11-28-2010, 05:18 AM   #18
ricepower
ricepower's Avatar
Lightbulb
after the swap, the gauge backlight, pointers(tach+speedo) is not working..Rest of the functions is working.
Below my observation:
My wiring harness is not the same. The canadian cluster has the illumination control and GCC/EU model don't have. To fix this, You have to swap/jumper or rig the illumination pinout of the new cluster.
I put it back my original cluster as I am annoyed without the illumination/backlight. Everything works fine. From here, I noticed also that they have different programming cluster daughter board. Tried to swap their daughter boards also but the results is more bad(none of the pointers is working).
Installing Speedhut tach, need help! RedRide DIY / Maintenance / Service 2 07-05-2009 04:02 PM
Canada tach in a US Yaris LB tiksman DIY / Maintenance / Service 49 02-27-2007 02:40 AM
