Old 08-19-2009, 09:25 PM   #1
Did you consider mounting your new seats to the base?
By the way, the carpet was completely saturated and the spare tire well was full to the top with water, hence the wicked rust.
Old 08-19-2009, 09:28 PM   #2
MGargano
Drives: 2009 Yaris Hatchback
I honestly didn't think of it since the new seats came with Wedge brackets, which are much lower than the OEM base. I figured the two seats would be at different heights if I were to mount the passenger to the OEM bracket and keep the driver on the Wedge bracket. Plus, I'm not sure if the new seat bolts up to the OEM bracket.
MGargano is offline   Reply With Quote
Old 08-19-2009, 10:17 PM   #3
OK. Just a thought, while I was under there. I was thinking that if you mounted the passenger seat to the OEM base, that you would also mount the driver seat that way. I haven't pulled that one yet, but it looks like there's an equivalent height set of mounting points on that side.
Anyway, I removed the sensors. With them off of the base I am still seeing voltage on the sensor signal wires. The airbag off light was on. I clamped all four sensors with c clamps and now have the airbag on light.
Old 08-19-2009, 10:23 PM   #4
MGargano
I forgot to mention that the new seats are attached to the base with torx bolts from the top (the same way the base is attached to the floor of the car), while the OEM seats attach to the brackets/sensors from the sides, so I think using the OEM brackets with these seats isn't an option for me.
Do you think there's something wrong with my sensors/system since I'm not seeing voltage on the signal wires? There is, of course, the possibility that I'm doing something wrong in testing for voltage, by the way
Any chance you could post a pic of your clamp set up so I can duplicate? Also, did you have to reset the SRS codes in order for the airbag light to turn to 'on'? Or did it just change as soon as you clamped the sensors?
Old 08-19-2009, 10:52 PM   #5
I am measuring between the center wire (which is the signal output) and a chassis ground. I am using a needle probe, which is a very thin, sharp probe. With the waterproof connector, I am sticking it into the rubber seal around the wire.
Old 08-19-2009, 11:12 PM   #6
MGargano
Ok, I'll definitely give this another try tomorrow. I don't have work so I should have plenty of time to mess around.
Out of curiosity, based on what you see so far, does it look possible to turn the airbag (and seat belt light/chime) on and off with a toggle switch? Or will we have to rig something using the OEM sensors?
Old 08-19-2009, 11:22 PM   #7
I'm not sure yet. Tomorrow morning I'll take a look at the signal output with an oscilloscope.
Possible Group Buy.. Racing Seats, Intakes? TinyGiant Items for Sale by private party 60 09-11-2009 02:40 PM
FS: Recaro Pole Position Racing Seats (black) -- socal 03Z33 Items for Sale by private party 13 12-07-2008 05:08 PM
sparco seats and pedals (pics) turboyaris Cosmetic Modifications (Exterior/Interior) 18 09-05-2007 02:43 AM
Sport / Racing seats worth the while? mikeukrainetz Cosmetic Modifications (Exterior/Interior) 10 11-19-2006 01:17 PM
Yaris Liftback Seats artyin General Yaris / Vitz Discussion 3 04-30-2006 04:07 PM
