ellenbetty
Drives: 2 2007 Yaris 3 door liftback Join Date: Nov 2008
Fog lamps as back up low beams.
Is it possible to safely use fog lamps as back up for low beams? I hate one eye monsters. Nether of my Toyota Yarises have fog lamps. If fog lamps can be used as back up for low beams, which fog lamps would be the best choice? OE? LEDS?
Total cost to install in a Yaris? (x 2 for me). |
#2 | |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
I would think that if you mounted them in the standard fog lamp position they would be too low to have any effective use as regular headlights. I had a Mustang that I mounted 100w fog lamps on a switch to either side of the pony in the grill to use as headlights since I had headlight covers. They seemed to work but they were real bright, and I only got pulled over once... for forgetting to turn my regular headlights on...! Paid maybe $50 for them. |
#3 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
![]() ![]() ![]() ![]() Drives: 2009 Meteorite 3dr Join Date: Jul 2009
Police officers I know will pull someone over for using foglights as headlights in town at night, and will possibly give a ticket for it.
Touchscreen DVD Navigation - 10" Bazooka Subwoofer - Kenwood Speakers - Toyota Premium Horn set AFE Pro Dry Air Filter - modified air intake box - 1ZZ-FE Throttle Body - Ultra Racing Rear Sway Bar & Front Strut Bar NST in cabin & engine bay SSK's - TWM shifter base bushings & cable bushings - Megan Racing C-Pillar Brace |
#5 | |
ellenbetty
Plus I suffer from neck, back and shoulder injuries from being hit by a van while in the USAF. So labor cost is also part of my question. If I lived in Maryland, I would just call Pep Boys and make a appointment to get the fog lamps installed. Maybe I should have added a question about where to buy the fog lamp and then have the fog lamps installed. Dealer would be a choice for OE fog lamps. |
The Fog lights Garm sells , are real easy to instal , 98% plug and play
just fit the lights and splice in 2 wires your done . Or you could spend another $170.US approx and buy the OEM Light stalk for the steering colum and be totally plug and play . the whole instal takes about 2 hr's . i would do it for you but your a bit far away . maybe another member on here might be willing to help you out . |
Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
please don't do it. I hate the truck guys who do it. And as said before, police will pull you over for it. I only use it when leaving my apartment complex at night to not shine my lights in my neighbors houses. After it get to the main road, I turn on my headlights.
![]() 2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
ellenbetty
ellenbetty
You talking about those LED circle after market head light assembly I seen on the Internet? Or LED lights to be placed where the fog lamps are placed?
#11 | |
![]() or i would be over there already
ellenbetty
I am not talking about a bunch of lights on top of a fake roll bar. My brother had fog lamps installed behind the grill of his Ford Ranger. I forgot about that. Higher but harder to install. But the fog lamp would have to put out about the same lumes and cover about the same area as low beams to do what I want. Fog lamps with the same output as high beam head lights would not be what I want. The built in mounts for OE equipment is not the only place I could mount the fog lights.
#13 | |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
Exactly. Not the roof ones. It isn't that hard to replace a $12 bulb in our housings. Just reach in and twist.
#15 | |
ellenbetty
Plus Ohio is known for some bitter cold winter weather. Some times a push button backup is the best solution. The behind the grill fog lamps would be better height wise for visibility. But I think the behind the grill fog lamps would be harder to install. I think the OE fog lamp kit would be easier to install. Since I have this round of modifications to pay off my credit cards, I am not in a rush to charge the cost of buying and installing fog lamps. |
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
I don't think fog lights will work as a backup... My old grand am had fog lights and the switch for the head lights went out, so i could only have on amber parking lights and my fog lights. The lights were too low and barely illuminated 10 feet in front of the car (dimly)... maybe if they were VERY bright (do they make projector fog lights?) it might work, but in my grand am, limping home was a miserable experience...
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell |
#17 | |
ellenbetty
As someone on this forum likes to day, just do it. So I ordered the fog lamp kits from MicroImage. Support the forum type of act. Even if OE fog lamps (or after market copies of Toyota parts), are not bright enough to do the job, and I need to add a second set of fog, LED or head light lamps behind the grill to do the job properly, I still need the wiring harness, instructions, and switch for the dash for the fog lamps. I just hope that the dash switch and wiring are thick enough to handle a second set of lights. Last edited by ellenbetty; 08-23-2009 at 04:37 PM. |
Run it throught the factory wiring for the first set ,
when and if you put a secound set in worry about the new wiring then personally i think you will be fine with just the OEM set up . |
| DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
| Did you order fog lamps? | Driver | New YARIS Purchase Forum | 27 | 11-29-2006 06:27 PM |
| Where to find Yellow capsules for fog lamps? | W.A.S.P | Cosmetic Modifications (Exterior/Interior) | 0 | 11-26-2006 01:01 AM |
