Old 08-22-2009, 10:14 AM   #1
sambo42xa
Drives: 07 YARIS Automatic/LiftBac/Red
Pickup Loss
Ok, I did a search for "loss of pickup" and found nothing. I got a 2007 with 51k on it and the only things that have been done to this animal have been new tires, air filter and oil filter changes.....that's it! Once I accelerate from a stop OR going to pass from changing lanes she doesn't have the "pickup" like she used to from new, naturally. I'm hoping I do not have to bring it to a shop since I like to do my own work. So, simple question that I'm sure has been asked on here before that there is a simple answer to but I cannot find it. I found "pickup", but it was for a guitar and marshall amp on here for sale. Any help would really be appreciated. Thnx.
sambo42xa
oh, three door liftback if that matters.
sambo42xa
sambo42xa is offline   Reply With Quote
Old 08-22-2009, 10:52 AM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
I thought you were missing a truck...
Old 08-22-2009, 01:29 PM   #3
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Try Gumout, Regane or Chevron, Techron and clean out the fuel injectors. Tire pressure at 38 psi.
Old 08-22-2009, 01:40 PM   #4
Seafoam Green is also highly recommended to de-gunk an engine...
Old 08-22-2009, 01:40 PM   #5
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
Full Tune up, simple as that
Its a Chao!!!
Old 08-22-2009, 02:08 PM   #6
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I would be a bit surprised if you already have carbon buildup or fouled up injectors.... but who knows...
i'd check spark plugs, air filter, then do the seafoam, first in the vacuum tube (intake) and then in the gas tank, after that if the problem is still there I'd inspect the timing belt to make sure it's fine.... if there still is no improvement, it might be something stupid like a dirty Mass Airflow Sensor.
Old 08-22-2009, 02:27 PM   #7
RedRide
RedRide's Avatar
I agree that your injectors might need cleaninmg as this is a common problem.
My favorinte injector/fuel sys cleaner is "Seafoam" engine treatment. I add a can to my tank about every 5-6k miles or so and it keeps everything clean. The cheapest place to get it is probably at WalMart.
http://www.seafoamsales.com/
Don't depend on the cleaners already in the gas to keep the injectors clean as the gas companys only put the bare legal minimum in it.
BTW Marshall amps are first rate.
Old 08-22-2009, 02:50 PM   #8
supmet
Drives: 2007 4 Door Yaris
seafoam at 51k? Are you guys smoking crack?
The yaris has no timing belt, its on a chain that is maintenance free.
A "full tune up" on a yaris is also known as "changing the spark plugs" - but one costs 200 and one costs 30 bucks.
How about we check filters, fluids, plugs before we possibly destroy vacuum lines and seize up a brand new engine. For all you guys know he could just be a hypermiler that doesn't realize his ECU is slowing him down because of his driving habits.
Sambo, I promise if you stick around there is lots of worthwhile stuff on this forum, and its not just a big seafoam infomercial. Usually people try to help diagnose things before they blurt out random answers that might help.
Old 08-22-2009, 02:58 PM   #9
auxmike
auxmike's Avatar
Timing belt?
Be careful where you get advice from. The internet is a dangerous place........
Old 08-22-2009, 03:20 PM   #10
RedRide
RedRide's Avatar
Yes! Seafoam at 51k miles. Why not?
If nothing else, make sure your injectors are clean before doing more involved things. Shure filters,etc might need changing,etc. However, that injectors are dirty afrter 51k miles and no cleaner hae been added is just about a given.
Also, Seafaom added to a gas tank will not "destroy" any engine components. Why do youn say this???
Random answers?
Old 08-22-2009, 06:52 PM   #11
sambo42xa
I'll start with the injectors since it was stated, "this is a common problem", which is kind of the answer I was looking for. All Other replies, thank you.
sambo42xa
Old 08-22-2009, 10:25 PM   #12
Yaris Hilton
Smile
I think it's pretty low mileage for an oxygen sensor problem, but they can slowly deteriorate causing reduced fuel mileage and power loss before they fail and set a check engine light.
Old 08-23-2009, 11:16 AM   #13
sambo42xa
I checked out the Seafoam links and I'm not really sure I want to put that stuff in my system.
Is this what some Mechanics use when cleaning Injecter's at the Dealer's/Shop's?
The Regane and Others that you would pour into your tank seems like you would have to do this on a continueing basis Everytime filling up with fuel. Being a dummy over here asking the dumb question's etc., I thought there would be something out there that you just pour into the tank and your good to go for another X amount of more miles (instead of a bottle each time at fill up...unless, by doing this, this cleans the system over a period of time?). Honestly, I think this could be the issue, dirty injecter's. And, as Other have said on here, "it's a start".
sambo42xa
Old 08-23-2009, 11:49 AM   #14
Reddog99
Reddog99's Avatar
Drives: '08 Yaris
If the problem didn't exist BEFORE you did the maintenance, and it does now, then the problem isn't injectors or spark plugs. It's something to do with what you have just done.
TIRES: Did you install bigger tires? If, so, then that's the cause. A taller tire effectively changes your gearing and will reduce acceleration. Either live with it, or install tires that are the same height as stock. Or install shorter tires, which will increase acceleration.
AIR CLEANER: Did you use a stock (Toyota brand) air cleaner? If not, then this could be the cause of the problem. A cheap replacement filter could be restricting the air flow. Or if you used an aftermarket oiled filter, there might be too much oil on it (thus restricting flow).
OTHER STUFF: Examine the engine compartment for loose wires or hoses that you might have disturbed while doing your maintenance.
Reddog99 is offline   Reply With Quote
Old 08-23-2009, 03:32 PM   #15
RedRide
RedRide's Avatar
"A little knowledge is a dangerous thing"
All the so-called "horror stories" aboput Seafoam soley concern putting Seafoam in the oil, sucking it up thorough vacumn lines etc, by people who really do not know what they are doing.
There are absoluly no problems connected to Seafoam when putinng it into the gas tank, only benefits.
It's simple, just pour it into the gas tank. It's fool proof.
Keeping injectors clean should be a part of routine maintenance and whether you use Seafoam or some other sort of qualty injector/ fuels sys cleaner, just do it and stay clear of all the mis information.
The cleaners in gas are totally inadiquate for the long haul and some suplimental cleaner must be added on ocasions.
Old 08-24-2009, 01:12 PM   #16
supmet
http://www.greatlakes4x4.com/showthread.php?t=59631
you gotta be careful with those products. my buddy used engine flush one time and all the shit in his engine plugged his oil screen and blew his motor.
http://www.jeepforum.com/forum/f197/...ont-do-836782/
Turns out the seafoam broke all the slidge loose in the tank and cloged the pickup screen on the pump so bad it could not suck any fuel through it.
http://www.benzworld.org/forums/w202...-additive.html
With that in mind I decided to added the SeaFoam to the gas tank rather than directly to combustion chamber via the brake booster vacuum tube.
After adding the product the I drove the C280 about 30 miles. The car ran really well and had rock solid idling.The following day my wife was driving the C280 and after a short trip to the store,she parked the car. Upon returning to the C280 and starting it, she noticed immediately that the car was idling very roughly and the CEL light came on. Driving home on the highway at highway revs , the car had smooth acceleration and drove as it normally does. Only at idle was it rough. Tried to drain fuel from Benz but needed a longer tube to siphon the gas. Decided to just use up the fuel ( full tank ) and see if it will "correct" itself as was the case with the 99 'Explorer
I drove the car this morning, and expected a rough idle at startup. Surprisingly, the car idle like a watch , this AM and during my initial 47 mile commute to work performed as it always does ( plenty of power and smooth running ). Once again ,upon leaving the highway and entering the city and having to stop I noticed that the rough idle has returned. CEL light is still on
I'm thinking fouled plugs or a fouled O2 sensor due to the carbon or guck in the combustion chamber being removed. It's strange that this morining at start up ( and for a while afterwards ) it idled beautifully. Only after the commute and entering the city , where I'd have to stop for stoplights did it idle roughly . Weird.
gas tank fool proof what???
I don't really have anything against seafoam, just 3 people recommending it without knowing ANY symptoms besides loss of power, and NO attempt to diagnose or check anything else.
kind of like having extremely limited knowledge about dude's car and recommending seafoam - right?
Old 08-23-2009, 03:41 PM   #17
RedRide
RedRide's Avatar
BTW, have you guys heard of the "nitrogen enriched" gas from Shell?
This is a bit of a scam.
Most fuels sys cleaners contain a class of chemicles call "amines" among other things
One of the properties of amines is that they have "free" nitrogen atoms.
So, the shell gas is simply nothing different than any other gas and "nitrogen enriched" is just a marketing gimmick
Old 08-23-2009, 04:40 PM   #18
R2D2
Crazy Oil Sniffer
R2D2's Avatar
Drives: MM 09 Yaris 5 Dr LB "Click"
But amines are the cat's behind when it comes to keeping your valves clean and Shell regular contains twice the minimum required by law (it's a top tier gasoline). I've talked to some industry insiders and use Shell if at all possible-my Yaris has had nothing but Shell since the dealer tank.
R2
"The howl was the sound of God’s casting pot, the morphing of my cells into shape, the forming of oceans out of molten premordial plasma. And I could feel it. I could cry for it. I could cry with it."
-The Fitful One
R2D2 is offline   Reply With Quote
Toyota projects first operating loss since 1941 KCALB SIRAY General Yaris / Vitz Discussion 26 12-23-2008 04:37 PM
