#1 | |
I guess the Japaneese liability laws are much different than in most countries. I wonder if auto up is avalible for the JDM yaris? |
#2 | |
If it is available on the JDM Yaris, it would be a bit of an issue to put on ours because the master window control is on the opposite door. The $50 DEI module would definitely be the cheapest/easiest way to get auto up/down on all windows. |
it's the MiniTRD
Drives: 2009 Polar White 3dr Yaris S Join Date: Jul 2009
just chiming in
I just had a 2008 Scion tC. On the drivers side are the two switches which both do FULL up and down. The passenger side has a single switch with Full up and down. There is no resistance sensing switch that I was ever able to tell. In fact you just kept holding the switch up or down to program the full open or close distance. BTW I looked see if they could be adapted to the Yaris, but no go unless you want to do some soldering.
Clark 2009 Polar White 3dr Type S it's the miniTRD http://www.norcalcarstyle.com/minitrd/ |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
