Old 08-30-2009, 05:33 PM   #1
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Have you cleaned it really well and looked for any drips or oozes of oil? A leak doesn't have to look very bad to go through a lot of oil fast. The dealer shop mechanics insist on replacing the oil plug gasket at every change (and charge a crazy price for it!) If you see a drop hanging on the plug, that could be enough to explain your oil loss. Put paper under the engine and see if you collect any drips.
If it's burning the oil in the engine, it may not appear to smoke much because of the catalyst burning the oil. That might explain the O2 sensor going bad early. I think that's covered under the 80,000 mile emissions system warranty.
Old 08-30-2009, 05:58 PM   #2
Toyo Chris
Drives: Yaris HB
I checked the floor and its dry and clean, and I didn't see any leaks. But if the O2 sensor is bad, it can burn the oil in the engine? Thanks for your help, I really appreciate.
Toyo Chris is offline   Reply With Quote
Old 08-30-2009, 06:06 PM   #3
Yaris Hilton
Smile
No, no, I'm saying that if the engine's putting too much oil in the exhaust, it could foul the O2 sensor. I'm also saying that the catalyst may be burning up much of the oil smoke if it is doing that, so you don't see it.
Old 08-30-2009, 06:10 PM   #4
Toyo Chris
Drives: Yaris HB
Oh, ok. So what could it be happening then if its not leaking? How can I know if its burning the oil or idk?
Florida Yaris Meet! 6/23/2007! Sabretooth Southeast 13 06-05-2007 07:46 PM
