Old 09-02-2009, 12:03 PM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
Resurrecting an old thread here - has anyone ever determined how much needs to be retrofitted to put ABS on a non-ABS LB? I've found the pump/control modules for affordable prices, but wondering how much else has to be added, or if the entire braking system is different? Was this a strictly-factory option, or added at the port-of-entry?
Old 09-02-2009, 12:14 PM   #2
bearda
bearda's Avatar
Drives: 2006 Mazda3 Sedan
Definitely a factory option. Usually there are a number of sensors that go along with the system for feedback you'd also have to get.
bearda is offline   Reply With Quote
Old 09-03-2009, 11:08 AM   #3
It would require the 4 wheel speed sensors (and wiring), the ABS ECU, the Brake Actuator Assembly, a new cluster (if you want the indicator).
I don't think the ECM needs to be changed or reflashed. The reason I say that is that the EPC doesn't specifically indicate a different ECM for ABS.
Old 09-04-2009, 05:56 PM   #4
bearda
bearda's Avatar
I've always been surprised at the negative reactions to ABS, as well. Personally I would much rather have a car equipped with ABS than one without, mostly because I realize the limits of my own ability. I'm a frequent autoxer and would like to think that I am at least an average driver. I know that there's a difference between threshold braking around a cone course where I'm looking ahead and anticipating each corner and when someone stops dead in the middle of a freeway, though. I also know that having one brake pedal means a 4-channel ABS system can deal with a situation where I've got two tires on an ice slick and two on wet pavement better than I can.
Does your liftback have ABS? BensVitz General Yaris / Vitz Discussion 75 05-24-2011 08:11 PM
ABS....Again~~ MeggiemobileSFLA DIY / Maintenance / Service 11 04-03-2007 10:12 AM
ABS Virgin!!! yaris-intuit General Yaris / Vitz Discussion 23 11-29-2006 01:49 PM
[Survey] Does your Yaris have ABS hans_fh General Yaris / Vitz Discussion 44 11-01-2006 11:11 PM
No ABS on Sedan?? hans_fh General Yaris / Vitz Discussion 2 10-12-2006 04:39 PM
